90 XJR rims
Will 18" rims from a 90 XJR fit a XJS or are spacers required. I have a chance to buy 4 with Z rated tires for $400. Bolt patten 5 x 4.5", waiting on exect tire specs
Good deal or not? |
BC XJS,
Have you got pics of the wheels? Standard wheels on a 1990 XJR are 16" rims. Paul |
1 Attachment(s)
Here they are
What width are they?
if they are 8" the offset will be 33, these will fit the rear but will require spacers for the front to increase offset to 20 |
Originally Posted by BC XJS
(Post 1443386)
Good deal or not? The Jag bolt pattern is 5 x 4.75"....at least until the mid/late 90s. Better double check what you are getting Cheers DD |
(Post 1443504)
Here they are
They do fit, but you will need spacers at the front and possibly small ones at the rear. The fronts you'll need at least 10mm (if you canget away with it) if not 15mm. Hope that helps.. Rich |
The tires are 255/45ZR18
(Post 1444114)
Also if they are off a later model, Jaguar changed the PCD, but I'm not sure when this occurred. |
Hi BC XJS,
The Penta wheels are working for me, see https://www.jaguarforums.com/forum/x...ls-xjs-142094/ I am using 3mm spacers on the front and none on the rears. |
I just saw the pic. They look good. Thanks for the help
