Changing the power steering rack on a 94 XJS L6 FAQ
Here is the procedure for changing the power steering rack on a 94 XJS L6 with pics.
Jaguar HELP!: Changing the power steering rack on a 1994 Jaguar XJS L6 Good luck! |
1 Attachment(s)
Attachment 165215
Daxter - many thanks for another great post......added to the FAQ for future reference. |
Hi there.
Thanks for the posts and the download info. I have an '85 XJS, how much different is the rack in my '85 XJS? I also downloaded the R134 retrofit info as well. My '85 has the original compressor in it. I had no pressure in the system, so the compressor probably leaks. Is there a place that will rebuild it or should I just get a new one? Is there a smaller replacement compressor for that? |
Originally Posted by magnoliav12
(Post 689422)
Hi there.
Thanks for the posts and the download info. I have an '85 XJS, how much different is the rack in my '85 XJS? I also downloaded the R134 retrofit info as well. My '85 has the original compressor in it. I had no pressure in the system, so the compressor probably leaks. Is there a place that will rebuild it or should I just get a new one? Is there a smaller replacement compressor for that? Rack is effectively identical as far as removing and replacing and fixings to the subframe are concerned. Greg |
Thanks again Greg. I've seen the Sanden and wondered about that. It seems to be a bit smaller. I noticed when I removed mine, apparently the "PO" replaced all but those 2 for the same reason. I had to take it apart in order to do the compression check. In the process of pulling the engine to work on the oil leaks and was going to handle the steering rack rebuild at that time as well. BTW, compression is good.
