lonejag |
06-17-2018 01:17 PM |
Convertible Top No Worky
My 96 xjs convertible top does not work. I removed and cleaned the top switch and put it back on. It worked just once. I swapped and used the top switch to raise both the passenger and driver's side windows and it worked. I used both window switches for thetop and the top did not work. I then went to the convertible top motor, fluid level is good. I have power to the motor (checked w/test light) I then removed the relays to check for power. When I placed my test light on each relay base pins, I only got power on the center pin (both times with key on, engine off and without the key in the ignition) Not sure what is happening here.
