orangeblossom
close
- Join DateFeb 2013
Liked:3,945 Times in 2,712 Posts
Quote:
Just a small point worth noting if you are not familiar with your engine, accessing and removing the sparks plugs is a bit of pig on the V12. Google - "Accessing the Vee" and you will see that you ideally need to move the compressor, cruise control bellows and throttle pedestal to work away in comfort. Be prepared to soak the plugs in-situ with some penetrating spray - they will be stuck in the thread like limpets - DO NOT force them, you will strip the thread and then you really need a mechanic.
When you do this you will also almost certainly want to dismantle the distributor - check both the mechanical (seized) and vacuum advances, replace the dist. cap and baked HT leads. Also check the EFI harnesses for cooking damage and repair with silicone tape as necessary, I also moved mine to the fuel rail to prevent a re-bake - a worthwhile exercise. That "should" be ignition sorted.
Then just pump the fuel out of the system (not as tricky as it sounds), swap out the coke can filter in the boot and fire her up. Dropping valve seats btw is a death blow for these engines, thankfully it is not nearly as common as people think and is relating to the temperature of the engine. But that's an entirely different topic - and probably what you will need to know about next!
Good luck
Hi TyranOriginally Posted by Tyran66
10 years eh? I just got mine back on the road after 15, so fear not. It cost me all in all about £900 doing the all the work myself with all of the major components intact. Ignore the pessimistic comments about scraping or abandoning your car to a mechanic (a non specialist generic mechanic can actually be a lot worse than a good diy'er from my experience) Treat yourself a workshop manual, read the free XJS book available online and dive in. Its good fun!Just a small point worth noting if you are not familiar with your engine, accessing and removing the sparks plugs is a bit of pig on the V12. Google - "Accessing the Vee" and you will see that you ideally need to move the compressor, cruise control bellows and throttle pedestal to work away in comfort. Be prepared to soak the plugs in-situ with some penetrating spray - they will be stuck in the thread like limpets - DO NOT force them, you will strip the thread and then you really need a mechanic.
Good luck
I'm really glad that I just read your post, as it never occurred to me that the plugs might be seized in their holes, so that will be one of the first jobs that I will do tomorrow, with lots of WD around the plugs.
Also I got the bonnet up and everything's in the way, so it looks like an all day job to get them out so thanks for your help.
Everything you need to know right here.
Accessing the Vee
Jaguar V12 H.E. Spark Plug Wrench
You will want to change the coolant as a priority - do not run the engine for any significant period of time without doing this. If your hoses are rotten you will want to pull and clean the rad at the same time. Start with taking the bonnet off if I were you
Accessing the Vee
Flint Ironstag
close
- Join DateNov 2010
- LocationHouston, TX
Liked:417 Times in 314 Posts
I'm assuming WD is WD-40? Honest question.
Quote:
I've not heard of the air pressure method that you have described and never seen the 'Mystery' oil for sale in the UK but I get the idea of squirting some oil down the bores.
All I've got to do is get the plugs out, which seems to involve dismantling half the fuel injection system, which does look a pig of a job but I'll give it a go.
The air pressure method is simply using a hose attached to an air compressor nozzle and the dipstick tube, thar forces pressure into the crankcase making sure that the oil pump won't cavitate and will pump the oil out of the panOriginally Posted by orangeblossom
Hi CalvinI've not heard of the air pressure method that you have described and never seen the 'Mystery' oil for sale in the UK but I get the idea of squirting some oil down the bores.
orangeblossom
close
- Join DateFeb 2013
Quote:
Yup! that's right, good ol WD 40Originally Posted by Flint Ironstag
orangeblossom
close
- Join DateFeb 2013
Quote:
Hi CalvinOriginally Posted by calvindoesntknow
I've never heard of that one before but it does seem to make sense, so thanks for responding.
orangeblossom
close
- Join DateFeb 2013
Quote:
Accessing the Vee
Everything you need to know right here.Accessing the Vee
Thanks for your most useful post, it does look a nightmare to do, especially since I can't get her out of the garage and therefore cannot take the bonnet off.
You have to remove the throttle tower to access the rear plugs and unbolt the mounts for the AC to move it out of the way.
If you have the factory spark plug remover, it is fantastic.
Marvel mysery oil is a lubricant and cleaner. I'm sure there are equivalents in other countries but by description the first thing that comes to mind is Synthetic high grade ATF. The MM is heavy in detergents so it is good at cleaning and getting into spots ( the synthetic would help getting into spots too) and it is an oil so it helps to lubricate. It in no way replaced regular oil, but helps loosen stuff up.
Unless explained to me another way the air pressure thing makes ZERO sense. The pump is submerged in oil, unless the oil level is low there is no way for it to cavitate. Pressurizing the crankcase isn't going to prime the pump in any way but if you are going to turn the engine over by hand you will probably pick up a little bit.
Also be sure to thoroughly clean the Vee and area surrounding the plugs before dumping any oil on them.
I replaced my plugs when I got my car and they were the originals. It wasn't that hard.
If you just go spraying wd40 and then get them loose the WD could carry any debri down into the cylinders, so make sure it is clean!
orangeblossom
close
- Join DateFeb 2013
Hi SidescrollinOriginally Posted by sidescrollin
You have to remove the throttle tower to access the rear plugs and unbolt the mounts for the AC to move it out of the way.If you have the factory spark plug remover, it is fantastic.
Thanks for your reply, the last time that I changed the oil was 8 years ago which was the last time I used the car before I parked it up.
The oil I used was Castrol Magnetec which I think is supposed to contain some sort of Moly Sulphides or something like that, which I hope is going to help.
And when I was clearing the junk out of the garage, I came across a proper Jaguar Plug spanner, which I must have purchased several years ago, which is going to be invaluable for this job.
When I try and turn the engine, should I have the gearbox in Park or neutral? or does it not really matter?
Should I turn the engine clockwise (when facing the bonnet) or does it not matter?
Also can I do the job without taking the bonnet/hood off?
What do you think the chances are of the engine being seized after a gap of 8 years?
Thanks for your help
Mikey
close
- Join DateOct 2009
- LocationPerth Ontario Canada
Liked:2,272 Times in 1,848 Posts
WD40 might be 'old' but it's not 'good' for anything except it's original design purpose which is displacing water. It's poor at best as a rust remover and not by any stretch of the imagination a good lubricant.
It's banished from my garage for many reasons.
There is more than likely some residual oil still on the cylinder walls even though the engine has not run for ten years. Dumping WD40 in the engine will wash that oil off and leave virtually nothing behind. I'd use a tablespoon of regular engine oil per cylinder and leave it at that.
Orange the chances of the engine being seized are slim on none, short of throwing a big-end shell or popping a starter motor - your not going to seize up any time soon.
However the chances of it being a bit reluctant and "wheezy" are fantastically good. Follow the advice given so far and you should be A-Ok.
orangeblossom
close
- Join DateFeb 2013
Hi MikeyOriginally Posted by Mikey
WD40 might be 'old' but it's not 'good' for anything except it's original design purpose which is displacing water. It's poor at best as a rust remover and not by any stretch of the imagination a good lubricant.It's banished from my garage for many reasons.
The more I thought about that, the more I came around to your way of thinking, so I think I will use the WD for other non critical stuff.
As a rust remover for bolts I have always preferred 'Plus Gas' but I haven't seen it on the shelves round my way for a while.
Thanks for your advice.
Doug
close
- Join DateMar 2008
- LocationPacific Northwest USA
Liked:11,724 Times in 7,587 Posts
Right. It's actually a mild *solvent*
Really? Now that's just going too far !
I find it very useful stuff for 1001 purposes....none of which have anything to do with lubrication, of course.
Plus, I love the smell. Not as wonderfully fragrant as Aero Kroil (great stuff) but still one of my favorites.
orangeblossom
close
- Join DateFeb 2013
Orange the chances of the engine being seized are slim on none, short of throwing a big-end shell or popping a starter motor - your not going to seize up any time soon. However the chances of it being a bit reluctant and "wheezy" are fantastically good. Follow the advice given so far and you should be A-Ok.
I'm really glad to have read your post as you have given me hope! as its easy to get disillusioned when faced with such a big job.
I've managed to pull the car over a bit away from the garage wall, though its still a bit of a squeeze to get underneath it.
What I've found is the floor pans look in very good condition but with flaking rust on the springs and wishbone arms, that should be easy to remedy if/when I manage to get her running.
Looking under the front of the Car I cannot see the flywheel, so was wondering if I have to remove the rubber spoiler under the front bumper or am I supposed to turn the engine from inside the bonnet?
The bodywork is amazing! with not a single speck of rust to be seen anywhere.
Taking off that front spoiler won't be an easy job as there is not much room to get round the front of the car and all the screws and bolts that hold it on are very well rusted so if it has to come off?
Its going to be the angle grinder on the head of the screws, if an impact wrench or mole grips will not do it.
Which leads me into Temptation! (enthusiasts look away now!)
Having done a bit of a risk assessment, there seems to be as much to go wrong by trying to fix the Car in the way that everyone has advised.
(1) The front spoiler will be hard to get off because the front is so close to the garage wall and I can't pull it back any further.
(2) All the fuel injection loom and all the throttle levers will have to come off which is certainly not an easy job with the lack of space to get round.
(3) The Aircon motor will have to come off just to get to the spark plugs and if one of them is corroded in, I might accidentally strip the thread.
I'm not being lazy here, I've done stuff like replacing the oil cooler and replacing the ignition switch on my Merc, which was actually much more difficult than doing an engine swap!
So I am very tempted just to put a battery on and flick the starter.
I think you can see my dilemma and where I'm coming from so what do you think?
Taking all that into account, which would be the lesser of the two evils?
Would you give it a try if it were you?
Anyone else is welcome to chip in.
Mikey
close
- Join DateOct 2009
I keep in the shed instead. Originally Posted by Doug
don't get discouraged when i was a teen ager and didn't have much money i used to pickup a lot of cars for free or less than scrap value, i would drive around and look for anything that looked like it had been sitting for a long time. look for weeds grown up around them ect. drag them home get them running drive them and sell them ect.
the most fun part is always hearing that old car cough to life for the first time. the second fun part was going threw and getting it running right. the least fun part was always replacing all the soft parts that were rotted. belts hoses bushings ect.
Iv gotten things running that sat way longer than yours. i got no doubt that you can get it running again.
I think if i was you i would spend a day getting yourself some more room to work around the car, aether moving stuff out from around it or getting it moved out. you can use some floor jacks to slide it sideways if needed maybe a few friends to help you push it around. or just move some stuff out from around it if that's posible. I don't know what it looks like or anything but getting a little room to work would be high priority to me.
I have heard that automatic transmission fluid is better to squirt liberally in the cylinders. It is thinner and very high is cleaning agents. I have had friends put a quart of AT fluid in the motor oil about a week before an oil change.
Some others may have some input on that.
Doug
close
- Join DateMar 2008
I've used ATF and light viscosity engine oil. I think both are fine.
I use one of those pull-trigger oiler cans with the flexible spout/tube. I get the flex nozzle right into the spark plug hole and give several good squirts in various directions. Let soak, turn engine a bit, repeat, repeat...over several days.
I don't think a *small* amount of oil dribbled into the cylinder does much good, and doubly so in a V-type engine as it immediately settles to the lowest point....leaving the rest high and dry.
This is a long read but I found it useful in its detail of the numerous problems that might have to be challenged in taking your car out of LONG TERM STORAGE.
Comment ...... I agree that not all that is written is needed or exactly the procedure that many would take.
I do agree with the author that caution and deliberate steps needs to be taken in the case of "LONG TERM STORAGE"
From MOSS MOTORS:
BRINGING A CAR OUT OF STORAGE
The payoff for the time and effort spent preparing a car for a long winter nap (or longer) comes in the spring. The process is essentially “undoing” the steps you took when putting it up for the season, and looking for problems that may have developed while the car sat idle.
Read the Spots
Take a good look under the car. The signs will give you an idea of any problems that you will need to look into. Coolant: check the hoses for rot and cracks. Look at the weep hole on the underside of the water pump – a leak here means the internal seal has perished. Inspect your radiator connections & fittings. Fuel: carefully inspect the tank for leaks at seams or on the bottom surface (rust pin holes). Examine all hose and line connections. Brake Fluid: failed seals in wheel cylinders, calipers or master cylinders. Bad hoses or hose connections. Rear Axle: seals at the pinion or axles. Steering: failed seals or boots. Gearbox: failed seals, fittings or plugs. Anything you find will have to be checked out and corrected as needed.
Critter Damage
Make a thorough inspection of the wiring in the engine compartment and under the car. Insulation seems to appeal to some animals and they can do some serious damage to the wires. Do the same in the cockpit. Any collections of nut shells or stuffing material is a reason to look more carefully.
Exhaust
Remove the plug from the tailpipe(s). Check the hangers and clamps.
Cooling System
If the car was stored for more than a year, drain and refill the system using a name brand antifreeze. Use a mixture of 30% to 50% antifreeze (no more than 50%). Check the hoses for cracks, especially around the clamps. Give all the hoses a good squeeze; any hoses that are suspect should be replaced.
Brake System
If the car has been sitting for 18-24 months (or more) and you use glycol fluid, drain, flush, and refill the brake system. Bleed the brakes. Check operation at all wheels independently. Have an assistant step on the brakes as you rotate each wheel one at a time. The brakes should clamp down and release smoothly. Any problem detected needs to be corrected before the car is driven. Have your assistant apply the hand brake gradually as you rotate each rear wheel one at a time. Again, the brakes should apply increasing friction until the wheel is locked up, and the release should be smooth. Perform any service as needed based on the inspection.
Hydraulic Clutch
Check the fluid in the clutch reservoir. Top us as needed (or change if the car has been stored for more than 18 months). If low, check the hose and slave cylinder for leaks. Have someone depress the clutch pedal while you observe the movement of the slave cylinder pushrod. If the pushrod is not moving, or moving only a little, bleed the clutch system. Fluid inside the dust boot of the slave cylinder indicates a failed seal in the slave, and that needs to be rebuilt or replaced.
Manual Clutch
Check all linkages for free play and free movement. Operate the clutch several times. If there is a provision for lubrication of the various joints, do so.
Oil & Lubrication
No matter where you live, and what you have done to limit it, some moisture will have gotten into the crankcase. With the appropriate oil, the amount of rust and corrosion will be minimal. If the car has been in storage for 2 years or more, change the oil and the filter before you try and start the car. Less than 2 years – plan on changing the oil and filter after the first 30 minute drive. Top up the gearbox. When was the last time you checked the oil in the differential? Might as well do that, too.
Suspension
Check all the suspension joints, pivot points and bushings. Visually inspect the rubber boots and seals for cracks, splits or other deterioration. Touch them – they should be soft and flexible. Hardened or stiff boots will soon crack if they have not already. Lubricated joints, like tie rod ends, will dry out eventually if the boots are torn because the grease will harden, losing its ability to lubricate. Correct any problems that you find. Lubricate the suspension, following the procedure in your workshop manual. Check the shocks for signs of fluid leaks. If they leak, they need to be replaced with new or rebuilt units. You can put that off for the purpose of a test drive by topping up the fluid in the shocks – use only proper shock oil.
Belts
Inspect all belts for cracks and replace as needed; adjust the belt tension.
Wheels & Tires
Air up the tires to the recommended pressure. Visually inspect each tire for cracks in the sidewalls or between the rows of tread. Remount the wheels & tires as necessary. Check the knockoffs or wheel nuts for tightness/torque. If the car is on jack stands, remove them and get the car back on the ground. Make sure the handbrake is set or chock the wheels.
Battery
The battery should be ready to install, fully charged. Check battery voltage – you should see 12-13.8V. Clean the battery posts and the battery cable ends. If you have a vintage-type lead-acid battery, buy a pair of the red and green felt battery terminal rings. Run a bead of silicone sealant around the base of each terminal/post. Press the felt rings down over the posts, down into the silicone. Coat the posts with and the insides of the cable connections with Vaseline (to protect against corrosion) and connect the cables after making sure you have the polarity right. Tighten the cable connections.
Ground Connections
Remove and clean ground cable connections both at the battery and the engine. A good battery and bad ground will not start the car. Wire brush the connections to bare metal. A squirt of WD40 will protect the bare metal for a while. I prefer a dab of copper grease. It will stop corrosion and guarantee a good electrical connection for a year or more.
Lights
Verify that the brake lights, turn signals, head lights and running lights all work properly. If one is not working, check the bulbs, the switch, the power feed and ground leads. Work through one light at a time, one component at a time until you discover the fault and correct it. Turn signals which don’t flash can be caused by a bad flasher, one bulb not grounding properly or a bulb of the incorrect wattage.
Lubricate the Pistons/Rings
If the engine has been sitting for over 90 days it is usually a good idea to get some oil to the rings. Mark the plug wires for future reference then remove the spark plugs and squirt a little oil into each cylinder. On the web, Marvel Mystery Oil is frequently mentioned as the oil of choice for this purpose, although no one explains just why. If you don’t have that, use the same oil you use normally. Let that oil soak for 24 hours. Crank the engine over by hand. Use the starting handle if you have one; otherwise use a suitably sized socket on the crank dog nut with a breaker bar. There may be some initial resistance, but the piston rings should break loose and the engine should spin smoothly after that. Leave the spark plugs out.
Fuel System
If you drained the system, you will need to get some fresh gas. As you add fuel, stop several times and check for leaks in the tank, fuel lines and hoses. If you did not drain the tank, and the fuel in your tank has ethanol in it, check for phase separation before you do anything else. There are products designed just for this purpose (like Water Probe Indicator, Moss 220-362). If water is detected, you can either re-emulsify the water/ethanol/gasoline mixture (using E-Zorb, Moss 220-355), or you can drain the old gasoline and replace it with a couple of gallons of fresh fuel.
Fuel in the Float Bowls & Lines
If the gas in the float bowls is old, remove the float bowls and drain the fuel. If there is old fuel in the lines, disconnect the hose/line at the carb and direct the end into a bucket or old coffee can. Energize the pump or pressurize the tank and push enough fuel to clear the lines and hoses of the old gas.
Getting fuel to the Carbs - Electric Fuel Pump
With a supply of known good fuel in the tank, reconnect the hose to the carb and energize the pump to fill the float bowls. The pump will click quickly and loudly until fuel reaches the pump; it will then slow down and become quieter. As the float chambers fill, the rising float will close the needle valve and shut off the flow of gas. The pump will stop clicking. A pump that continues to click rapidly indicates a problem either with the supply of fuel from the tank or a stuck needle valve in the carb, which will be obvious because there will be gas coming out the overflow pipe on the float chamber. Whatever the issue, it needs to be corrected. Be aware that the gaskets and seals in the carbs will dry out and shrink if left for a long time. When the fuel first reaches the carbs, there will probably be leaks, and you will need to attend to those before you go any further.
OK, Where Are We?
Cars run because three things happen in the right order and in the right quantity: spark, compression, and fuel. We should have spark (once we put the plugs back), meaning enough and at the right time, because the car was in tune when we put it up for the season, and the fully charged battery is in place. Compression should be fine, again because the car was tuned up before we put it up and because we have added oil to the cylinders. We have fresh fuel in the carbs. We are almost ready to start the engine. Most bearing wear occurs in the first 10-20 seconds every time the engine is started. That is because the oil is present in a thin film only, and oil under pressure has not reached the bearings yet. Cold oil is not as good a lubricant either. An engine that has been sitting will take time to get the oil to all the moving parts, and we need to get the oil moving throughout the engine before we fire it up.
Building Oil Pressure
There are several ways to pressurize the oil system. Some of you have a tank that can be filled with oil and pressurized with air, and then plumbed into an oil gallery. These are perfect for loading the system with oil under pressure. If you have such a tank, use it to pressurize the oil system. This will pre-oil all the bearings and moving parts in the engine and minimize the chance of damaging bearings or other internal engine components on start-up. If you don’t have such a tank, you will use the starter to spin the engine over and pressurize the oil system. The last place to get oil is the rocker assembly. If you pull the valve cover, you can easily see when oil reaches this point. If the engine has been sitting for years, or if this is a fresh rebuild, it is strongly suggested that you remove the tappets (carefully noting their original position) from the engine to prevent scuffing the face or foot of the tappets. The load on the engine bearings is minimized by having the plugs out. Turn the key to the start position and hold it there. As the engine turns over, the oil pump will fill the oil galleries and push oil into the main and con-rod bearings. With the engine turning over, the oil pressure gauge should come to life and once you see pressure on the gauge and oil at the rocker assembly, shut it off. Reinstall the plugs and reconnect the plug wires. Reinstall the tappets in their original locations with a dab of ZDDP paste or other cam lube on the foot of each tappet.
Start the Engine
If you are in a garage, push the car so the rear end of the car is outside. Place a fan where it will keep the exhaust gas from blowing back into the garage. Make sure the transmission is in neutral. Engage the emergency brake. Do not “pump the gas” as SU and Zenith carbs do not have accelerator pumps and you won’t accomplish anything. Engage the choke and turn the ignition key to the start position. The engine should crank over and start. If the engine does not start immediately, you need to determine why before you start “fixing” things. Random adjustments will make the situation worse.
Once It Starts…
Let the engine warm up without revving the engine or “blipping the throttle” but don’t leave the choke fully engaged; ease it in as the engine warms up. Take a good look around, checking obvious problems. There may be smoke as the various components heat up. You can verify thermostat function by feeling the top radiator hose. When the thermostat opens, the top hose will warm up quickly. As the systems come up to temperature, keep an eye open for leaks.
Trying Clutch & Gearbox
Step on the clutch and try to engage reverse gear. If you can, lift off the clutch and back the car out into the driveway and stop. Try first gear. With the clutch working normally, you are ready for a short test drive. If you cannot get the car in gear, and the clutch is moving as it should, the clutch friction disc is very likely stuck to the flywheel, the pressure plate or both.
Frozen Clutch
A car left standing will sometimes develop a frozen clutch because the friction disc is trapped under tremendous pressure between the flywheel and pressure plate, and either the metallic particles in the friction disc or the adhesive matrix in the disc fuse to the flywheel or pressure plate. When this happens, the engine crankshaft is fused to the input shaft of the gearbox. Before you try to cure this problem, be absolutely sure the clutch linkage (hydraulic or mechanical) is working as it should. There are two simple things to try first. Start the engine in neutral and let the engine run until it is well and truly warmed up, say 15 minutes. Push the clutch pedal to the floor and blip the throttle several times, sharply raising the engine RPM to 2000 RPM. The heat from the engine and the rapid change in engine speed will often break the friction disc loose. If that does not work, there is another simple procedure that may work.
With the engine off, pump the brakes and hold the pedal down (we don’t want the car to move an inch). Press the clutch pedal to the floor. Shift into 4th gear. Turn the key to the start position and run the starter motor for one second. What this does is use the torque of the starter motor to rotate the flywheel, breaking it loose from the friction disc. As soon as the flywheel breaks free, the engine will crank over normally. If this does not work the first time, try it a couple more times. It that does not do it, stop. There are other more aggressive ways to break the frozen clutch free; call Moss Technical Services.
Test Drive
Assuming all has gone well to this point, you are ready for the first test drive. The purpose of the test drive is to exercise all mechanical, electrical and hydraulic systems so that you can find any remaining problems. Plan out a route about 20 minutes in a circle around your house so that you can walk back if need be. As you drive, listen to the various clues. Is there a miss in the ignition? Does the car pull to one side or the other when braking? How is the steering? Stiff? Loose and “wandering”? How about the shocks? How is the oil pressure? Any problems with the gauges? Back in the garage, make a list of the things you discovered on the drive. Check your fluid levels (except your coolant level; you cannot do this till the engine has fully cooled). A change will indicate a leak you need to find. Top up as needed. After attending to any minor corrections, plan your next drive. Include a run at higher speed on a local highway. After another 30 minutes on the road, back in the garage to take stock of your situation. There will probably be a few things that need attention. Once these are done, you have a car that is ready to hit the road. Because of the time invested, you can set out with a much higher level of confidence than you might otherwise have.
Conclusion
There is no doubt that putting a car into storage and bringing it out is not a trivial undertaking. The longer the car is in storage, the more important it is to consider all the steps presented here. While obviously somewhat generic, the issues covered here apply to all older cars, and this list should be supplemented by additions of your own based on your experience. It should also be clear that the time and effort invested in preparing a care for storage pays off in the time saved in getting the car back on the road. It is also clear that these lists really are the routine maintenance operations that we need to do regularly, and doing them at the beginning or end of a season’s driving makes some sense. It also makes driving the car every month throughout the year when conditions permit much more attractive - the problems that develop with a car in storage are best avoided by simply using the car regularly. That does not eliminate the need for the routine service that has been included in the procedures given here - that still needs to be done using a schedule that suits you. G
From MOSS MOTORS:
Read the Spots
Critter Damage
Exhaust
Cooling System
Brake System
Hydraulic Clutch
Manual Clutch
Oil & Lubrication
Suspension
Belts
Wheels & Tires
Battery
Ground Connections
Lights
Fuel System
OK, Where Are We?
Start the Engine
Once It Starts…
Frozen Clutch
Test Drive
Conclusion
orangeblossom
close
- Join DateFeb 2013
First of all my Thanks to:
Ezerider-Doug-Catnlion-Calvindoesntknow-MLP442009-Sidescrollin-Tyran66-XJS Fan-Flint Ironstag-Mikey-Ronald P and anyone else that I have forgotten to mention, who have been so supportive and contributed to my Post with loads of good advice as well as ideas.
This is going to take a bit of believing so stay with me.
The Car was jammed in the garage when I put her in mothballs in October 2005 and hadn't been started or turned over from that day to this, owing to a bereavement in my family which had left me totally devastated.
That was about 8 years ago but I guess its now time to move on.
Though after an 8 year layup, I suddenly started to realize I had probably left it too long and thought the engine may well be seized up.
Owing to the confinement of the garage, I didn't have much room to work and dismantling all the the throttle connections and wiring looms etc, just to get to the spark plugs was going to be a tough job.
And in the event that something went wrong, like stripping the thread on a spark plug, then that would have been a difficult job to put right.
If I'd had the space to do it, then I would have done it, as I have done a lot worse jobs than that when I've had the room.
So having done a bit of a risk assessment, I flipped a coin and decided to put a battery on and so borrowed the one off my daily driver my Merc.
What happened next was surreal!
Having connected the battery, the boot light then came on, as too did the interior lights in the doors, then I put the Key in the ignition and turned it to position 1 and nothing happened at all.
At which point I thought it was game over!
But about 10 seconds later everything kicked into life! The instruments lit and the blower fan, came on but wouldn't switch off.
Then I heard the fuel pump priming the fuel injection system which seemed to go on for ever! but was probably only for a couple of minutes.
Then with my heart in my mouth I turned the key.
The engine spun over no more than six times and then burst into life!
at which point the oil light went out and the oil pressure started to build and though it took 30 seconds it felt like 30 weeks!
Then it ran on its own at fast idle for 5 minutes during which time the exhaust pipes, jetted out white smoke.
After which time the idle speed dropped back to normal.
So then with my foot on the brake and my hand on the handbrake, just in case, I put her into reverse and then did all the shunting about that I needed to get her out into the Sunshine after 8 years.
Everything worked including the hood.
It was just like a Normal Start up, on any day of the week and the engine just purred like a kitten.
My thanks to Castrol Magnetec, as I don't think that any of that would ever have happened without it.
