Replacement brake accumulator
I couldn't find the original part for my 1994 XJS 4.0, at a reasonable price, so thought I would look at alternatives. Ordered a Bosch unit as fitted to AMG Mercs and Maybachs. It is a little smaller but screwed straight in. Took 32 seconds to charge initially and takes 23 brake pumps to empty it so I think it will work just fine. $85 Ebay.
https://cimg1.ibsrv.net/gimg/www.jag...31acfdf741.jpg https://cimg3.ibsrv.net/gimg/www.jag...8612eae433.jpg |
Cool, Keep us posted. I just replaced one on my xj40 and it cost me 200 or so from Welsch Ent |
I have a vacuum booster system. Wgat year was the accumulator done away with. You say yours is a 94. My 95 has vacuum booster.
ABS
Originally Posted by carsnplanes
(Post 2039993)
kansanbrit,
Thanks for the info. It's always useful to know of alternative parts. carsnplanes, The brake system changed to a traditional servo type at VIN 198335, around November 1994. Cheers Paul |
Originally Posted by kansanbrit
(Post 2040095)
Does your 95 have ABS?
Originally Posted by ptjs1
(Post 2040200)
kansanbrit,
Update
Still working fine. Amazingly no bleeding was necessary.
Hi Kansanbrit
What sort of Tool did you use to unscrew the Accumulator, as I am going to put a new one on my Car 'Cherry Blossom' How much of a problem was it to unscrew? |
I used an allen key socket with ratchet and held the assembly from twisting by using a G clamp. Once it's held solid it just needs a bit of force to break it loose.
Hi Kansanbrit
Many Thanks I did my Car Today but getting the Ball unscrewed was a bit of a Nightmare! |
Care to weigh in with any longer-term issues with this accumulator? My 1994 XJS V12 is in need of a new one and finding a less expensive alternative would be nice.
you could also use this
from a 98 to 03 Cadillac. Goes the other way, next size up, but still fits and under a 100 bucks. I have found that they are all over the agri machine business, combines and harversters and such. If you can find a decent industrial hydraulic supply house, they either have or could order one direct from the manufacturer. |
Originally Posted by 71 MKIV
(Post 2581628)
Good to know. I am always a bit apprehensive about using an alternative part unless others can say for certain that it fits and works properly.
Originally Posted by MSGGrunt
(Post 2581618)
Nothing ventured nothing gained. I just ordered the GM 25676065 accumulator.
Total price with shipping was $107.00 |
I currently have one in my 94 XJS and 94 XJ40
My 93 works great with the cheaper accumulator. Hasnt missed a beat in 3 yrs i think? Time slips by lol
