The oil cooler bypass on a 4 litre is done using parts 3,4,5,6 & 7 on the Jaguar diagram here:
Oil Filter-3.2/4.0 Litre - Parts For XJ Series from (V)720125 to (V)812255 (X300) | Jaguar Heritage Parts UK They go for about £40 / $65 second-hand. Have a look on ebay. Paul |
I can find out by blocking the oil cooler flex lines or just pinching them off and then starting the engine to see if I have oil pressure at the gauge. Thank s all for your replies.
Cheers, RagJag |
Aftermarket oil cooler
Has anyone thought of using a aftermarket oil cooler & AN fitting & hoses ? The coolers come in all sizes.
Larry |
ptjs1, since I can't see the openings in #5, I need to know if the openings are blocked off. If so I can remove it and block them off in my workshop. By doing this I can eliminate the seep from the flex hoses and the concern that the old flex hoses will spring a leak. Then to the other chore of removing the Tupperware under skirt to access the cooler for removal.
Thanks, RagJag |
