Trans Fluid Question
Looking to change the fluid in my '93 4.0 ZF4hp24e.
I would like to go with synthetic but have no idea what is currently in there. Are there any issues mixing regular and synthetic fluids? Anything else I should look out for? Using this filter: |
Nevermind . . .
Found this on the Valvoline site: Is it OK to mix synthetic ATF with a conventional and/or synthetic blend ATF? Yes. Synthetic ATF and conventional fluids are 100 percent compatible with each other. |
