V12 6.0 idling high
Hello. New member here from Sweden!
I have probolem with 6.0L V12. When cold engine is idling about 1600rpm. After around 5 minutes itīs normal and about 750rpm. Is it possible to adjust the idle when engine is cold? |
its called open loop. as far as i know theres no way to adjust it.
Originally Posted by jaguarlars
(Post 426309)
I have probolem with 6.0L V12. When cold engine is idling about 1600rpm. After around 5 minutes itīs normal and about 750rpm. Is it possible to adjust the idle when engine is cold? Cheers, |
I have replaced the valve with a new one but it doesnīt help. Well car runs perfect when hot so maybe I should be satisfied!
The issue you discribe is the cold engine boost from the Auxiliary
Air Valve. It sounds like it is working just as it is meant to. If you do not want it I could use it! Mine is stuck and I idle 2000 RPM and it does not come down ever. |
After reading your post again it looks like you might have 2 that work,
what would you want for one of them? |
Does the V12 has idle control valve to control the idling?
Originally Posted by kev's xjsc
(Post 428888)
