Homelink buttons to control exhaust valve
Old Sep 19, 2013 | 12:23 PM
R_Rated's Avatar
Default Homelink buttons to control exhaust valve
Guys,
How cool would it be to use the built in garage door opener to control opening and closing the exhaust valve?
I was browsing another forum and ran across this:
Originally Posted by keitheva
I know this has been mentioned before but not sure if anyone actually fitted it, a relatively easy way to add a remote switch for F22. Non-destructive fitting, very easy to remove if you want.
First, buy this (available in many places but this was the cheapest I found (no affiliation)),
Corvette C6 Z06 Mild to Wild Exhaust On Demand Switch, Corvette Exhaust Controll
The fuse won't work as-is because the placement of the attached wires prevents the fuse from being fully inserted in the correct orientation. Cut the red wire and attach a spade connector. For the white wire, cut back the shrink wrap where it attaches to the fuse, and pull out the wire (it already has a spade connector on it). The red wire is power for the relay module, the white wire is switched. Insert the red spade into the F22 slot towards the center of the fuse box (always +12V when the ignition is on). Insert the white spade into the F22 slot towards the outside of the fuse box (either +12V or 0V depending on position of relay). Ground the black wires somewhere on the chassis (I used the metal post where the battery cut-off switch is located). I velcro'd the module to the outside of the fuse-box. You could cut holes in the fuse box lid to pass the wires if you want, but I just left the lid off.
On the remote,
"ON" = the circuit is closed, +12V passes through the white wire = the same as F22 being in-place = flaps closed = Quiet
"OFF" = the circuit is open, +0V passes through the white wire = the same as F22 being removed = flaps open = Loud
It will always start in the "OFF" (Loud) position, no matter where it was when the ignition was last turned-off.
Caveat emptor!
Their F (Fuse) 22 is our fuse 19 for our exhaust.
R_Rated's Avatar
Here is a pic of the install:
Here's a pic. Ignore the red/black wire that I have spliced to the white wire with the blue connector, I just did that for a tap to make it easier to check the voltage at the white wire. You can get the spade connectors at Radio Shack (get the narrowest ones you can find).
Old Sep 19, 2013 | 01:45 PM
hawaii's Avatar
Very cool in deed! This can be used for the dynamic suspension fuse as well.
Old Sep 25, 2013 | 12:17 PM
amcdonal86's Avatar
Very cool, but I am unsure of how to apply this to our cars. Where do the homelink wires come out of?
Old Sep 26, 2013 | 07:49 AM
R_Rated's Avatar
There are no homelink wires. You program the garage door buttons just like you would with a garage door opener. There are enough buttons to control 3 different garage doors. I'm proposing use one to control the exhaust.
The kit I posted has a key fob with a button to control the unit wirelessly. You use that to program your homelink following the identical instructions in the Jaguar owners manual as you would for the garage door opener.
Old Sep 26, 2013 | 02:16 PM
Stormdk's Avatar
Does it become so much louder, that one needs a on/off switch?
Is it not just a slight deeper tone after the fuse removal?
Old Sep 26, 2013 | 02:23 PM
R_Rated's Avatar
Absolutely not... I simply pulled the fuse on mine and its still really quiet. With the active system it sounds no different than a family sedan [jag] except under WOT which is unsafe really in this car with all of the power since flooring it for just a few seconds gets well over most speed limits.
Old Sep 26, 2013 | 03:55 PM
amcdonal86's Avatar
Ah. What I actually want to do is to connect and disconnect the active suspension module (2007-2009 models) on demand via Fuse 14 in the footwell fuesbox. Do you think it would also work for this purpose?
So I take it if you program it with the homelink buttons, hitting one button will "break" the circuit" until you either turn it back on, or restart the car?
Old Sep 26, 2013 | 04:55 PM
R_Rated's Avatar
This is correct; for both questions. Follow the same instructions for whatever fuses you'd like to disengage (up to 3). No cutting, no drilling, no DIY altering anything about your interior at all and completely reversible with no trace.
Old Sep 26, 2013 | 07:47 PM
amcdonal86's Avatar
This is brilliant!!!!!!
Old Sep 27, 2013 | 11:30 AM
amcdonal86's Avatar
Does anyone know of any other such device that doesn't cost $90??
Old Sep 27, 2013 | 01:46 PM
R_Rated's Avatar
I've looked for other products and the average cost is $150-$200. $90 is a bargain for what you get!
Old Sep 27, 2013 | 03:13 PM
amcdonal86's Avatar
Nonsense! I'll just save my pennies and pull over, get out my flathead screwdriver and my fuse puller every time I want to hear the exhaust. Oh, and I'll need some time to schedule an appointment with my chiropractor, too...
bamforp
Aug 14, 2024 05:36 PM
02jagstype
23
Oct 23, 2022 07:03 PM
Jandreu
Jun 30, 2022 03:10 PM
fingers
Sep 8, 2015 03:54 PM
XFR_Gold
Sep 2, 2015 12:24 PM
