'07 owners (and others), antenna opinion please.
My car hits the paint booth tomorrow. Command decision time for the morning. $600 removes the antenna and fills the hole (welded aluminum backing plat with filler the most likely process.)
So now I have to ponder the reality. Is making the telescoping antenna go away worth $600? (I suspect I can negotiate down to $500, but that's just a gut feeling right now.) I understand per other posts that an alternate antenna can be adapted for under $50, and having 10 years electronics maintenance in my background says that part is pretty easy. Whats your thoughts? I see no resale gain or loss, so it is just a personal "looks" preference. I totally understand the "it's my car" thing but wanted impressions from others. Not often you get a car repainted, so it may be my cheapest chance if I want to pull the trigger. Would you get it done? Thanks all, Vince |
Originally Posted by CleverName
(Post 506912)
So now I have to ponder the reality. Is making the telescoping antenna go away worth $600? (I suspect I can negotiate down to $500, but that's just a gut feeling right now.) I understand per other posts that an alternate antenna can be adapted for under $50, and having 10 years electronics maintenance in my background says that part is pretty easy. Whats your thoughts? I see no resale gain or loss, so it is just a personal "looks" preference. I totally understand the "it's my car" thing but wanted impressions from others. Not often you get a car repainted, so it may be my cheapest chance if I want to pull the trigger. Would you get it done? Thanks all, Vince :icon_bunny: Out of curiosity, what on earth happened to your paint that you need to repaint the whole car? |
I think most of us will agree that your antenna is old school and detracts from the lines of the car. Since you're already thinking about getting rid of it, if you don't do it you'll probably regret it, particularly if you plan to keep the car for at least another 2 or 3 years. Only you can decide if it's worth the cost.
Just my:icon_twocents: |
I think it's highly unlikely that a prospective new owner would even know the antenna had been changed. And if he knows the car has been repainted he'll understand you taking the opportunity to remove it. No downside if the antenna bugs you, and if it's worth the money to you. Not sure it would bother me personally, unless it was prone to getting bent, stuck, corroded, etc.
Bruce |
(Post 506918)
:icon_bunny:
Out of curiosity, what on earth happened to your paint that you need to repaint the whole car? I certainly hope insurance goes after Oregon DOT for some of it. Vince BTW whats up the the rabbit wearing a pancake on its head? ^^ I've seen it a couple places now? |
The antenna is old school as someone else pointed out. I was gonna do this on the 07 I had, but then traded it before actually doing it.
I really don't consider this a "mod". I would consider this an "upgrade" in both functionality and cosmetic appearance. To me a mod is something that an owner does that makes the car different in some way than other cars of the same make. You will simply be bringing the car up to and inline with later model cars. You are not adding god-awful neon lights under the car or some ridiculous looking ricer fender skirt. I say do it and bring the lines of the rear end up to date. And what a fine rear end it is. :) |
I'd just remove the fuse and keep the doe in your pocket or use for something else.
The antennae doesn't really bother me one way or the other. Based on your other posts Vince I'd save the $600 and put it towards the 18" wheels you've discussed. I'd bet you'd get more pleasure out of them.
Steve |
Originally Posted by sjtyrer
(Post 507240)
Steve Yup already made the call... Antenna stays.... Vince |
