Originally Posted by Flynnstone
(Post 2084104)
They all appear to be left inners. Not the prized right inner. ☹️
(Post 2084040)
I’ve order the correct one from the local jag dealer. Not cheap, but I’m in a tight time line to get car approved.
and if the rear light clusters on your car are reversed ( that is, the white and red fog lamps are reversed) would that lead you to suspect that at some point there was accident damage to the rear and the wrong units were installed? |
One reverse lamp is fine for provincial approval.
It just needs to be white. Also, both were Red. Somehow a UK fog lamp was installed on car. This is now fixed. The only pain I have now is to get the window tint adhesive off the windows. Argh. |
For the adhesive, carburetor cleaner works fantastic, on a soft scrubby pad. Takes not much time and little mess. Just be careful to not get any on other surfaces.
