Aftermarket Cats
Help please
Bought aftermarket Cats for my 4.2 xkr, 60,000 miles, bought from Catman in England, plus new oem sensors Only just passed emissions Anyone bought aftermarket? Is this a dead end - do I need to pay 3k for oem originals? Any info appreciated |
aftermarket cats suck,
used cats from a 350 find a way to make it work |
Originally Posted by wsn03
(Post 2743169)
The cats need to be hot to function properly so you maight need to give the engine some trottel when the measurment is done. X350 4.2 NA or R has same engina and gearbox as the XK and XKR. There are also lots of other components that are very similar. The part numbers does however differ. https://www.berkshirejagcomponents.c...s-c102x2777409 |
If you “just passed” the emissions test and if you are occasionally throwing a code for catalyst efficiency; put a short bung on the downstream O2 sensors.
I too am not a fan of aftermarket cats. I bought a set of pacesetter or Davaco head pipes with cats that were supposedly aftermarket replacements but they were made of the cheap version Catalytic material versus the OEM expensive stuff. I think I paid $200 for each cat and pipe.
I’ve had nothing but persistent, and or recurring codes 0430 and less frequently 0420. I look at my short term fuel trims and they look great but when I look at the outputs from my secondary O2 sensors, it’s obvious that the cats are not doing what it’s supposed to do. I’m about to make a post on that but long story short I’ve been messing with this damn 0430 code for about three years now, and I can not Stop it permanently or make it go away. I’m about to take the damn head pipes off and reinstall the original pipes that I had. The only reason I removed the original parts was bc of bad welds. The pipes I took off and replaced looked like somebody had welded a new catalytic converters, but the welds were horrible and looked pretty restrictive. I think they necked the pipe down in diameter as it entered the cat. So I replaced them thinking I was doing myself a favor but as I said, I’ve had is nothing but trouble since My car is an 06 type R |
There are a couple shops near me that rebuild catalytic converters for a reasonable fee, usually $300-400 depending on the style and case material. They break open the case and rebuild the guts using all new material. Their timeline is usually one week to complete.
Originally Posted by Aarcuda
(Post 2744075)
There are provobly low quality modern metal cats to be found. But if you buy a well known brand (google and find) then they do work well for a very long time. But there can still be problems as the engine magament is a sensitive system. Meny use ”mini cats” at the secondary sensor. But I have also found posts that the car works better without them. |
(Post 2744075)
I’ve had nothing but persistent, and or recurring codes 0430 and less frequently 0420. I look at my short term fuel trims and they look great but when I look at the outputs from my secondary O2 sensors, it’s obvious that the cats are not doing what it’s supposed to do. I’m about to make a post on that but long story short I’ve been messing with this damn 0430 code for about three years now, and I can not Stop it permanently or make it go away. I’m about to take the damn head pipes off and reinstall the original pipes that I had. The only reason I removed the original parts was bc of bad welds. The pipes I took off and replaced looked like somebody had welded a new catalytic converters, but the welds were horrible and looked pretty restrictive. I think they necked the pipe down in diameter as it entered the cat. So I replaced them thinking I was doing myself a favor but as I said, I’ve had is nothing but trouble since My car is an 06 type R See how i get on with my aftermarkets Thanks for your response |
Originally Posted by Cee Jay
(Post 2744086)
Originally Posted by spalmgre
(Post 2744814)
Jag oem cats are ceramic and therefore restrictive. They do also crack and start ratle.
