Aftermarket Cats
Old Apr 22, 2024 | 06:01 PM
wsn03's Avatar
Default Aftermarket Cats
Help please
Bought aftermarket Cats for my 4.2 xkr, 60,000 miles, bought from Catman in England, plus new oem sensors
Only just passed emissions
Anyone bought aftermarket?
Is this a dead end - do I need to pay 3k for oem originals?
Any info appreciated
Old Apr 22, 2024 | 09:37 PM
xalty's Avatar
aftermarket cats suck,
used cats from a 350 find a way to make it work
Old Apr 24, 2024 | 04:49 AM
spalmgre's Avatar
Seek X350 forums as there seam to be meny 200 cell cats instalations. Meny report no problems. Maybe there is some other problem that the new cat can not hide (filter). O-sensors must also be of original Denso brand.
The cats need to be hot to function properly so you maight need to give the engine some trottel when the measurment is done.
X350 4.2 NA or R has same engina and gearbox as the XK and XKR. There are also lots of other components that are very similar. The part numbers does however differ.
https://www.berkshirejagcomponents.c...s-c102x2777409
Old Apr 25, 2024 | 03:57 AM
guy's Avatar
guy
If you “just passed” the emissions test and if you are occasionally throwing a code for catalyst efficiency; put a short bung on the downstream O2 sensors.
Old Apr 25, 2024 | 09:34 AM
Aarcuda's Avatar
I too am not a fan of aftermarket cats. I bought a set of pacesetter or Davaco head pipes with cats that were supposedly aftermarket replacements but they were made of the cheap version Catalytic material versus the OEM expensive stuff. I think I paid $200 for each cat and pipe.
I’ve had nothing but persistent, and or recurring codes 0430 and less frequently 0420.
I look at my short term fuel trims and they look great but when I look at the outputs from my secondary O2 sensors, it’s obvious that the cats are not doing what it’s supposed to do. I’m about to make a post on that but long story short I’ve been messing with this damn 0430 code for about three years now, and I can not Stop it permanently or make it go away. I’m about to take the damn head pipes off and reinstall the original pipes that I had. The only reason I removed the original parts was bc of bad welds. The pipes I took off and replaced looked like somebody had welded a new catalytic converters, but the welds were horrible and looked pretty restrictive. I think they necked the pipe down in diameter as it entered the cat. So I replaced them thinking I was doing myself a favor but as I said, I’ve had is nothing but trouble since
My car is an 06 type R
Old Apr 25, 2024 | 10:24 AM
Cee Jay's Avatar
There are a couple shops near me that rebuild catalytic converters for a reasonable fee, usually $300-400 depending on the style and case material. They break open the case and rebuild the guts using all new material. Their timeline is usually one week to complete.
Old Apr 27, 2024 | 10:52 AM
spalmgre's Avatar
Jag oem cats are ceramic and therefore restrictive. They do also crack and start ratle.
There are provobly low quality modern metal cats to be found. But if you buy a well known brand (google and find) then they do work well for a very long time.
But there can still be problems as the engine magament is a sensitive system. Meny use ”mini cats” at the secondary sensor. But I have also found posts that the car works better without them.
Old Apr 29, 2024 | 09:32 AM
wsn03's Avatar
I will get some originals eventually and get thrm rebuilt perhaps.
See how i get on with my aftermarkets
Thanks for your response
Old Apr 29, 2024 | 09:33 AM
wsn03's Avatar
thanks Cee Jay. There is a company in the UK who does rebuilds. Annoyingly my originals were scrapped but I can get some more - think I will do this during the year for sure. Worth trying
Old Apr 29, 2024 | 09:35 AM
wsn03's Avatar
Thank you, appreciate the info
Hojones716
Jun 23, 2022 08:03 AM
bmcinsd
Jan 14, 2018 09:05 PM
hoodun
Sep 23, 2015 12:17 PM
Doug Dooren
Oct 25, 2013 09:24 AM
