Any concerns with 2009 XK convertable versus newer? General things to watch for?
Hello. I'm a new member. My wife is thinking about a XK and I'm doing some research. I've been a long standing member on elisetalk (now lotus talk), and it look's like you have a great community here as well.
My question are: 1) Is there anything we should be aware for with 2009 convertable versus other years? Any big fixes? Any major upgrades or significant improvements? changes to the warranty? 2) Any general things to watch out for with these cars? Thinks you should check to see if they are worn out or signs of abuse? Common failures or things people try to cover up? thanks in advance! PDQ |
I own a 2009 Jaguar XKR with is the Supercharged version of the XK.
It is a convertible and I have had no reported problems of any kind. |
If you can afford the differential, go with a 2010 or later. Why? 5.0 liter engine as opposed to a 4.2 liter and hp increase that goes with it. Tighter construction, more choices as to driving style - 2010's and later have winter, and dynamic options which were not available on 2008 xks.
In addition, If you follow some of the threads in this forum you will find that there were several problems with the earlier xks that seem to have been ameliorated with the vehicles built after the 2009 model year. |
Aircon drain getting blocked and leaking into the passenger footwell is the main thing that crops up again & again. I'm not sure what percentage of cars actually suffer from it, but it gets discussed regularly.
Originally Posted by ralphwg
(Post 916636)
In addition, If you follow some of the threads in this forum you will find that there were several problems with the earlier xks that seem to have been ameliorated with the vehicles built after the 2009 model year. 1. Electronic limited slip differential 2. Sport mode on the transmission that will only shift when you use the paddles (the 4.2 will still kick down when you floor it and upshift when you hit redline--very annoying) These are probably the two most important upgrades when it comes to driver enjoyment. |
(Post 917079)
Originally Posted by Ngarara
(Post 917128)
The e-diff is only fitted on the 5.0 XKR, not the 5.0 XK
I have a 2008 black xk conv I bought in 2011 with 23k miles now up to 41k and have had no problems worth mentioning. Love the car. I wish I had a 2010 for the extra HP but you could probably save a few bucks with a 2009 if that's an issue.
(Post 916636)
In addition, If you follow some of the threads in this forum you will find that there were several problems with the earlier xks that seem to have been ameliorated with the vehicles built after the 2009 model year. Ralph has owned many Jaguars and offers good advise. If you can afford the 2010-on you will not regret it. Everything is updated and upgraded in the 2010-on models. Shop nation wide and be patient and you will be rewarded. |
Obviously, if a 2010 or newer is in your grasp, do consider it... However, do not be put off by a older XK, as you will find them fantastic cars, with impeccable reliability and build quality.
The first generation (07-09) ran a "tried and true" power train. The 4.2L has been around and proven for over a decade and a half, (something the 5.0L cannot yet claim) so faults there are far and few except for a general wish for slightly more power. The AC drain tube is a known problem, as it plugs and leaks water onto the passenger footwell. A Service bulletin was released to address the problem, so check that that service has been done as it is costly to remove the dash to properly address the fix. Onboard entertainment is sub-par on both first and second generations (something Jag should never have released in the first place, and failed to update even on the 2010 and newer... (Cheap KIAs have better maps and bluetooth) BTW you cannot update the audio in either generation as much of the cars systems are integrated to it... Back seat in either gen is for groceries only... Be aware that no real aftermarket parts or upgrades exist for the car, so what you buy is what you will own.... All in all, despite the weak infotainment, XK is a great car to drive and own. Amazingly reliable, stunning to look at and a buying decision few regret. BOL, Vince |
Originally Posted by CleverName
(Post 917298)
The first generation (07-09) ran a "tried and true" power train. The 4.2L has been around and proven for over a decade and a half, (something the 5.0L cannot yet claim) so faults there are far and few except for a general wish for slightly more power. Then again, they an XF with 60K they are doing an engine swap on, but I think something happened to the engine from a prior service (not my shop) and they are swapping for a used engine... Around 6K for the whole job with engine. |
I would not go below a 2010. 2010 had changes from the 2009. The 2010,2011,2012s all pretty much same. There are good buys out there for 2010 and up just keep looking and be very careful of the vehicles history tract it down you will not be sorry you did. South Florida and Naples, Ft. Meyers areas are good locations for pre owned they sit in a garage and used on sunny days or just in the winter and are dealer kept as to service etc.
(Post 917298)
Originally Posted by beh2010
(Post 917509)
You seem to imply that those of us in first generation cars made a bad buying decision, and I can assure you we did not.... My '07 XK is a flawless and amazing car. I reached as far as my finances would allow (which fell far short of a second gen), yet remain proud to own such a wonderful car. Liking a second gen XK is no reason to bash the first. Both are great cars. Vince |
CleverName, I am NOT bashing just giving an opinion. The question was concerning 2009's or other years. While the first gen's are good if buying now why not go up in years for a newer model if that is what one wants to do. If your looking for something older fine there are very good xk's out there. It all has to do with what the buyer wants that's all.
(Post 917698)
While all generations are gorgeous cars, there are many considerations, and some will be more important to some buyers than others. I personally think if a buyer's budget allows for the newer generation that it offers the best value and performance. Depreciation has slashed even 2010 prices, and you can still find some with factory warranty, which would be extremely important to many. Let the warranty fix things that the previous owner may have just put up with. On-going maintenance should be about the same across all model years, but demand and resale value of the 2010 and newer I predict will be much higher because overall it's a better car in every way...and that's just the way it is with probably most cars. Once you're out of warranty and footing the bills yourself it just makes sense to invest where you're likely to get the best return. Jaguar's image is being recrafted towards performance, and the newer XK, and R versions particularly, reflect the new brand's image and values. Now none of that should be interpreted as anything other than things that a prospective buyer might like to be aware of, and may want to consider. There are many threads and posts that outline the extensive upgrades done for the 2010 MY if the original poster is interested. |
I have not had any reported problems with A/C drain issues on my 2009 XKR. In fact up until today there has been no issues what-so-ever. The car runs flawlessly.
We sure don't want to place any unnecessary emotional of mental burdens on someone who might be considering a 2009 or under. It is easy to take many of these posts as problems that are appearent on all models 2009 and under, when that is not the case. I am thrilled with my 2009 and see no problems with the horse power that my 4.2L Supercharged engine provides. Keep in mind that we have speed limits within the USA which most are well under 60 miles per hour when NOT driving on interstate or highways. With the bulk of daily driving somewhat local the 5.0L sounds great to have, but in most cases is really not necessary. If you have the need for speed, buy a car that you can put on a track for fun, and beat the living hell out of it. These beautiful XK/XKR's are best on a nice cruise somewhere. |
Thanks!
All the feedback has been awesome and I really appreciate both sides of the 2009 coin you have shared. It is _exactly_ what I was looking for. Obviously cost is an issue for or she'd be looking at a 2012 or new :-)
That said it sounds like there were significant non cosmetic changes between 09-10. As much as it kills me to say this, my wife has zero concern for HP or cornering - she'd probably take a 4 cyl, if it were available :-). It sounds like we'll keep looking for both 09's and 10's until and keep in mind the delta between two when looking price. On last question, is there a way to visually look for the change to the AC drain, or do you just have to rely on service records. Thanks again!!! PDQ |
I do not think there is a quick way to check that. I would suggest once you find a vehicle, take down the vin number and contact Jaguar direct or if its at a Jaguar dealer have them print it out. I believe there were tech reports put out on this very issue. Jaguar USA is very helpful.
Originally Posted by PDeMaio
(Post 918149)
For someone who is not a 'spirited' driver, a benefit of the 5.0 model is that it has Winter mode, which makes the car more drivable in slippery winter conditions, something that I expect you see from time to time in Seattle. If your wife will never drive the car in snow or ice, then that's not a significant factor. |
