Change your e-diff fluid!
For the past 2 years I've owned the car, after cold starts, the first few tight turns would always result in a judder/vibration from the rear. I noticed a lot of the older XFRs were getting this and finding out their diffs went bad months later.
My car only juddered for a turn or two, and only at slow speeds. Nothing too awful, and I always babied it for the first few minutes of driving anyway. But I decided to service my e-diff last week and replace the fluid, simply because I thought it was the right thing to do, despite Jaguar's insistence of "lifetime fluid." The color of the old fluid was a very dark brown, and while the viscosity of the fluid looked okay, I could see a few speckles of metal here and there. Size wise, they were smaller than any speckles of glitter, but when I looked carefully, it was there. It's made a huge difference in response, the shifts are smoother, and the power is transmitted to the wheels better. There were always some quirks I would occasionally notice from the rear end during shifts, and now that's all gone. Most importantly, the judder is gone too! No more noise from the diff. My car has only 36K miles on it, it's a 2012. I bought it with 24K miles. I don't do donuts or crazy burnouts. I'll give it the beans every now and then, but I avoid hard launches and such. Next up is servicing the transmission fluid. OEM fluid is expensive, and the total cost is nearly $600 - which is mostly parts. |
Also the diff will not overheat so quickly. If you drive these cars on a circuit, the diff can overheat after three or four hard laps. Change the fluid and it takes much longer for the warning to appear.
Originally Posted by ArnoldKay
(Post 1838387)
I've been noticing the same symptoms. Did you do it yourself? How many quarts does it take?
thanks |
Originally Posted by nicobaires
(Post 1838419)
I've been noticing the same symptoms. Did you do it yourself? How many quarts does it take?...thanks
yes, I hear/feel this too on my 2010 xkr. a tad concerning. I will too change the fluid.
1 Attachment(s)
(Post 1838470)
thats the tranny kit, I meant the differential Below are the specifications for the Rear Drive Axle/Differential: |
had this issue on my XFR, felt an uncomfortable juddering at low speed turns..........changed the diff fluid and it fixed that issue immediately. cost me about $100 at my local indi
Since I don't know, I will ask a possibly stupid question here;
Does the E-Diff require a Friction Modifier? As I do not know what method the e-diff uses for lockup, I don't know the proper specs. |
Originally Posted by Cee Jay
(Post 1839458)
... As I do not know what method the e-diff uses for lockup, I don't know the proper specs.
From an article by Wes Siler in 2009: "Another first for Jaguar is the new Active Differential Control (ADC), the final stage of the supercharged V8 driveline. Designed to give improved traction and dynamic stability, the electronically controlled differential continuously adapts to both the driver's demands and the amount of grip available at each individual wheel." "Operated by an internal electric motor and 'ball-and-ramp' mechanism, the differential contains a multiplate clutch which transmits or 'vectors' torque to the wheel with most grip and therefore maximises the car's traction. The multi-plate clutch assembly is designed to prevent excessive differential slip, but differs fundamentally from a conventional traction control system, which uses the brakes to counteract differential slip, after it has occurred." The fluid specification M2C192A Synthetic is for fluid WITHOUT friction modifiers: https://www.fcsdchemicalsandlubrican...nsaxle%20Fluid |
Well, there ya go. All I had to see was "multiplate clutch". I searched for just under an hour and couldn't find any info.
So, a Friction Modifier seems to be required. I thank you for your information, Sir. |
(Post 1839520)
Originally Posted by jagtoes
(Post 1839527)
So why does the post's last sentence say WITHOUT friction modifier.
As always, it is best to refer to the vehicle Owner's Manual or Workshop Manual to check the specification by VIN. |
Because that fluid doesn't have any.
I DID find this on a Fluid Spec page: Ford M2C192-A plus M2C118-A Synthetic hypoid gear oil with friction modifier. Far as I know, having a friction modifier when it ISN'T required doesn't do bad things. The reverse is no-bueno. Since "Clutches", I'd assume a FM would be a good thing. I REALLY don't want to burn up my E-Diff. If I'm either missing something or flat-out Wrong, please tell me! |
+100.
For anyone who's reading this thread and has the "shudder from the rear end when turning from a stop" (cutting left across traffic, etc.) here's my experience, from a previous post, for those who haven't read it (I was also saying nice things about my warranty, but you'll get the drift): https://www.jaguarforums.com/forum/x...y-ever-184802/ |
e diff noise
Hi
I also had the noise and vibration from the diff on tight left turns Had the fluid changed and although better still got the noise sometimes, so put the SDD laptop on it and found no codes but that you can recalibrate the diff motor Did this and now all good 2009 XKR 106000 miles Now jus t got a knock from left hand front when making a slow tight right turn |
What is SDD laptop? Where did you get it?
Originally Posted by talltim
(Post 1840896)
Hi
(Post 1838419)
thanks |
Originally Posted by pk4144
(Post 1840522)
+100.
