Which diagnostic scanning/reset tool are you using on your XK150?
I think I need to get one. I am using IOS products, so that is a factor for me.
What are you all using? And, can you reset fault codes? Go deep into the history? Thanks in advance. |
I bought an open box one of these cheap on EBAY and use it with my iPhone:
https://www.walmart.com/ip/Autel-HT2...Tool/964022238 I do have the full factory diagnostic gear (SDD) on a laptop as well for the heavy stuff but I keep this little device in my centre console so it is always to hand. It will read all of the modules in my XK and I can reset codes with it. I posted a little write up when I first bought it and attached some of the module scan reports: https://www.jaguarforums.com/forum/x...-ht200-217969/ It is probably at the budget end of the market but Autel seem to produce lots of high end gear too and it does everything I need when it comes to scanning, monitoring and resetting codes on the go. |
Thank you. I will check into this one.
