New diagnostic toy - HT200
Old May 18, 2019 | 09:45 PM
u102768's Avatar
Default New diagnostic toy - HT200
I took a punt and bought a new diagnostic took a few weeks ago and it arrived a couple of days ago. It was discussed on one of the other lists, XF I think, and a couple of people who bought them seemed pleased with them. There is only one review on EBAY and it got one star but as the forum guys seemed happy with it I thought I would risk $30.
The amount of information it can pull out of the car is incredible for such a cheap device. It is made by Autel and is a HT200. Once the dongle is registered using a smart phone you can download the diagnostic tool for one marque for free so I naturally chose Jaguar. Other ones can be purchased for just over $20.
I had a quick play with it yesterday and the attached PDF's show some of the scans available. The device detects which car modules it can talk to then you can select each one individually and query the fault codes or look at the live data stream. You can either display the current value, turn the metric in to a graph or display it as a gauge. My only criticisms are that you don't appear to be able to produce custom screens with just the metrics you are interested in and to create a pdf of the results from a live stream you have to scroll to the bottom of the screen to make the values populate.
The attached PDF's contain some of the data I captured and, as you can see, it captures things like ABS wheel sensor speeds, steering wheel angle, air-con blower fan speed, humidity, air-con system pressure, blend flap positions, carbon dioxide sensor level, temperature of the hi-fi amp, differential status and clutch and oil temperature, engine oil temperature, sump oil temperature, calculated oil volume, the status of many buttons or switches (on or off), seat motor output, damper status, etc, etc, etc. It also has the usual OBD scanning capability and seems to be able to pull codes from most modules plus reset the codes.
I will probably still just use Dash Command to monitor my car for more regular use because it is customisable and quick to get going while I am driving but I can see this other tool having its uses as well.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old May 18, 2019 | 11:49 PM
Patrick Wong's Avatar
Thanks for providing your evaluation of this device. I'm interested in that because the SDD clone that I had bought a couple of years ago no longer works, even after I tried to reinstall the software.
Do you believe that the DTC logged by the DiagReport file are correct?
Were you able to clear the historic and intermittent DTC?
Old May 19, 2019 | 03:24 AM
u102768's Avatar
I believe so. I haven't scanned the car with SDD for a little while but I recognise most of the codes.
Fan 3 control - circuit high is because of my tune, the parking sensor ones are probably because my front bumper was removed earlier in the year whilst some work was being done on the car, the lamp ones are probably because I changed a lot of bulbs out for LED's and have had them disconnected whilst the power was on.
I haven't tried resetting the codes but I presume that it would work. I can try tomorrow if you are particularly interested.
I have a working SDD as well but tend to only use it for flashing modules as it takes a little while to crank it up. I will probably use this new dongle for checking errors now as I can keep it in my car and use my other dongle with Dash Command for monitoring.
Old May 19, 2019 | 09:20 AM
Thanks for this info. No need to reset the DTC if you would not otherwise be inclined to do so. I will place my order from an eBay supplier today!
I have a current problem where the Smart fob is not recognized by the car, and I have to insert the fob into the center console receptacle to get the XK to start.
I'd like to see if any current DTC are logged related to this issue. The 12V battery is new and fully-charged; the fob CR2032 battery is also new and measured 3.2V upon installation.
Old May 19, 2019 | 10:06 AM
Reverend Sam's Avatar
Oops... My mistake. I retract my last comment.
Old May 19, 2019 | 11:31 AM
kj07xk's Avatar
I take it that the fob works correctly for all other functions? (doors, lights, etc.)
Old May 19, 2019 | 04:11 PM
Yes, the car responds appropriately as each of the 4 fob buttons are depressed. I tried both fobs and the car does not recognize either with regards to starting, unless I insert the fob into the center console slot.
Old Jun 2, 2019 | 08:01 AM
I received the HT200 last week and had time to mess with it last night and this morning. The first step is to download the Jaguar software which is a two step process. One to download Jaguar software and the second to download a Diag-Europe app. Once that is done then the system will work.
It is pretty cool to be able to see the many parameters logged by the various ECUs when the car is running, if you are interested in seeing fuel line pressure, fuel rail temp, manifold pressure, short and long term fuel trim, etc.
The HT200 revealed many DTC logged on ancillary systems. With regards to the fob not being recognized until it is inserted into the center console holder, the relevant DTC are B1B01-67 and B1B01-87. Apparently there is a fault either with the instrument cluster unit or the start control unit (anyone know where that is) or the associated wiring.
Anyway I agree that this is an amazing deal for $30 on eBay and is still great at the $50 retail price at Walmart.com. I would advise against buying an eBay "open box" unit because the prior owner may have already downloaded the one free software; hence you might have to pay $22 for each additional manufacturer software download.
Old Jun 2, 2019 | 06:42 PM
u102768's Avatar
Glad you like it. Mine was an open box and I worried about that when I read the instructions but didn't have any issues getting my one free software. It is potentially an issue though.
Old Jun 24, 2019 | 05:36 PM
Ter11's Avatar
This sounds pretty amazing. But how could I buy this ht200 delivered to Europe? I cannot find any listings in either amazon or ebay right now. Only Walmart, but they do not send overseas.
Br
ter
Old Jun 24, 2019 | 07:29 PM
Canadacat's Avatar
Would this be capable of reflashing my power seats.i currently have an issue with one passenger seat not bring able to go forward.
Old Jun 24, 2019 | 07:51 PM
u102768's Avatar
Br
ter
https://www.ebay.com/itm/Hyper-Tough...0/254270981860
https://www.ebay.com/itm/Hyper-Tough...0/192958153391
A lot of the ones I saw for sale when I bought mine looked like returned ones so I wonder if Walmart sell off returned items cheap and they end up on EBAY?
Old Jun 24, 2019 | 07:52 PM
u102768's Avatar
I don't believe so. I think it will only display codes and reset them.
Old Jun 24, 2019 | 08:10 PM
Br
ter
The Autel HT200 is no longer shown on the manufacturer's website. The Autel AP200 seems to be the equivalent, and they are currently available on Amazon.
Old Jun 25, 2019 | 01:02 AM
Ter11's Avatar
Dear all,
Thank you all for the helpful hints! I tried to find out about the differences between HT200 and AP200, but the information on the web is scarce on this. Is it sure that the AP200 is the newer model and does it have the same or more abilities as the HT200?
br
ter
Old Jun 30, 2019 | 03:06 PM
Ter11's Avatar
I have ordered the autel ap200 via aliexpress. Will post here after I can give it a try when it arrives.
Old Jun 30, 2019 | 06:04 PM
MarkyUK's Avatar
I took mine to a specialist with exactly the same problem, he just held the forward button forward for 6 seconds and it then worked, he said it's usual when a lard@rse sits in the passenger seat and reclines it too far back, the motor shuts down as a result.
Old Jul 4, 2019 | 02:32 PM
Ter11's Avatar
Update: received my Autel ap200 today. It seems to be a great tool. I found no difference to the ht200. Read more about the dtc error codes that I retrieved today with the ap200
afs/swivel headlights failure, post #45:
https://www.jaguarforums.com/forum/x...3/#post2094147
Pedestrian system failure warning, post #53:
https://www.jaguarforums.com/forum/s...58#post2094158
Br
ter
Old Jul 4, 2019 | 03:12 PM
Canadacat's Avatar
Smile
Thanks I will give that a try, though I don't know if my wife is going to like being called a lard ****, but if it fixes the problem I am fine with it.
Old Jul 5, 2019 | 04:53 PM
Canadacat's Avatar
Well so much for that, now neither power seat works , nothing I guess I will go for reflash
