Enabling Audio Connectivity Module
I live 200 miles from the nearest Jaguar dealership but will be there for another purpose in the next week. Is it possible to have them enable the Auxiliary Audio Input and have me install the module at a later date? I have seen posts where people remove the module and the Aux icon remains on the system screen. I am driving a 2008 XKR Portfolio convertible. Any advice? Thank you.
https://cimg6.ibsrv.net/gimg/www.jag...9065d93e24.jpg |
The AUX input can be enabled by a dealer, regardless if the ACM hardware is connected or not, just show them this picture;
https://cimg2.ibsrv.net/gimg/www.jag...6ae5bc3780.jpg You don't need the ACM hardware though, there are other options, see here https://www.jaguarforums.com/forum/x...ed-acm-217898/ |
Hi i use SDD (your picture) for activate AUX function and it's not activate on my screen (my car 2007 xkr), why ?
Thank's Marc |
You ever get it enabled?
I've been calling around dealers in Los Angeles and Ventura County to see if they will enable the aux audio on my 2008 XKR. It is really difficult to communicate what I'm trying to do to the service managers. Anyone in Southern California get this done? |
Originally Posted by Sovejag13190
(Post 2114764)
I didn't want to mess with buying a cable and installing the software. Anyone in SoCal done this? |
I did quite a bit of testing and re flashing using clone Chinese Mangoose cable , works great knock on wood. I cant suggest it to others though in case you will not get so lucky it works great for me but at the same time I have other equipment to fix any issues if reflashing fails.
Originally Posted by moth
(Post 2114900)
Thanks for the information. It is quite thorough with pictures.
(Post 2114686)
Cost to enable AUX
Just curious. I have been wanting to add the Bluetooth to the AUX and move away from the fm modulator connected to the antenna. What did the Spokane Jag charge for this?
Thanks. |
Aux function
Originally Posted by sargentrn1
(Post 2186741)
Thanks. |
Expect an hour labor charge unless you dealer charges in 30 minute increments. It's a 10 minute job but they prolly have a minimum rate. Also, have to put it in the bay, pull it out, etc...
Hi here my tuto (french sorry) to activate AUX : HERE
Aux
Originally Posted by Sean W
(Post 2186778)
(Post 2114686)
