Front License plate
#121
Y'all are making this harder than it needs to be. Go to Amazon and buy one of these. It mounts up underneath - no holes in the bumper - and you can slide it underneath for those times when you don't want to display the front plate. I put one on my XK right away as I bought it in FL and live in NE, which requires a front plate on display. Easy peasy.
#122
GhostRider9000 (11-13-2018)
#123
As I did, just buy the "Show 'n Go". "Hide it" when you show and "show it when you go". It bolts beneath in the front center of the pan. Needs only one additional 5/16" drilling combined with an existing bolt already in the belly pan. The center mount location is between the oil coolers on either side when the frame is in display mode.
Geez, this is such a no brainer, a "cave man" can do it! Just not worth the $70 dollar fine, at least here in Merry-land.
LoudHogRider (06-23-2017)
#124
#125
I leave mine up pretty much full-time as NE requires the front plate to be on display as well. But it's handy to move out of the way for car washes and if you want to show the car, plus the next owner isn't burdened with filling in the bumper holes if they happen to live in a state that doesn't require a front plate to be displayed. To each their own, but the "Show N Go" works just fine for my needs.
The following 3 users liked this post by LoudHogRider:
#126
RedRider, saw your post, thank you. Also, someone showed me the hole already on the bumper that is plugged with one of those push and remove things on the far left facing the hood. Just need a screw in type contraption stuck on the back of the plate and it goes right in with a few turns. Seems the most logical place to me. I'll just hold onto the hole cover in the glove compartment or whatever you guys in the UK call it.
#127
Received 1,896 Likes
RedRider, saw your post, thank you. Also, someone showed me the hold already on the bumper that is plugged with one of those push and remove things on the far left facing the hood. Just need a screw in type contraption stuck on the back of the plate and it goes right in with a few turns. Seems the most logical place to me. I'll just hold onto the hole cover in the glove compartment or whatever you guys in the UK call it.
Think they call it a 'tow hook plate holder'.
GhostRider9000 (06-23-2017)
#128
#129
We here in Canada also need to display front plates. Im not a big fan of any front plate mounted on my cars and have come up with a solution that works for me. I cut my plates top and bottom to about 3/8 of an inch of the numbers then I affix them to my front bumper via high quality automotive two way tape. I bend the plates slightly to conform to the bumper 'curve'. I have been doing this for about 12 years now and have been pulled over I think 3 times. Never ticketed. If your going to do it, dont buy cheap tape.
#132
RedRider48, not sure if this was for my post or for another before mine...... here is what I have done as per the post....
I prefer this as opposed to the full on licence plate holder. it looks better than in the pic
Held on by very good quality two way construction tape able to handle the elements. As I had changed plates on one of the other cars with a bit of patience and a low setting on heat gun removal was possible with no issues to the paint
#133
[QUOTE=Fstbmw1;1709094]RedRider48, not sure if this was for my post or for another before mine...... here is what I have done as per the post....
Yea nice trick but wouldn't work here in NY. Looks like you modified the plate which is a ticket here . Maybe 2 because it was done intentionally as opposed to being damaged. But not a big problem as it might be only a $250 fine and a return with proof of it corrected.
#134
[QUOTE=jagtoes;1709099]
jagtoes, technically cutting a plate can also earn you a ticket here. I have 4 vehicles all with cut plates, and, as I mentioned, I have been pulled over maybe 3 times over many years. All gave me a verbal warning and a bit of a smirk. maybe I have been overly lucky, having said that my neighbour cut his about a year ago and he has not mentioned any ticket issue.
#135
[QUOTE=Fstbmw1;1709122]
Good deal so it looks like your LEO's aren't after revenue like they are here.
#136
Some perspective:
We have the luxury of calling a cake "death by chocolate", to the starving world its a uniquely first-world problem to die from a chocolate cake.
In the same vein; Black guy shot in head by cop for missing license plate! in the head.
Black Man Samuel Dubose Shot in Head by Cincinnati Cop Ray Tensing - NBC News
#137
Some perspective:
As a side bar I used to live 1 mile away from a place called The Hitchcock Estate in Millbrook NY. This was the place where Dr. Tim Leary and his followers used to come on weekends. So every Friday , Saturday and Sunday there was a police roadblock/checkpoint at the gate house. Every car got stopped and was asked a few simple questions. The ones pulled over usually had drugs. Even though the cops knew me and where I lived they still stopped me. After a while we just talked about family and at that time my XKE.
#138
This is a good example of either not having the front plate if required or if you have any other simple issues with your car. Things like headlight out or broken tail light and so on. My BIL (retired NYS trooper) has always said that usually something out of sorts leads to bigger issues. The the case above based on the article it appears the driver had alcohol and was belligerent. He may not have deserved to die but it also appears that resistance led to the death. Cops go on the offence once their requests are denied. The data shows that motor vehicle violations end up being bigger issues.
I would have pulled you over without a roadblock. Etype in the sixties, near Leary's house, you were bound to have drugs and girls.
MarkyUK (11-04-2018)
#139
Need to get the cat inspected. Need a front plate. Zip ties or tow hook? Jaguar dealer sales guy told me he saw a tow hook at WalMart for a Jag XKR too, but can't seem to find the same image link he saw. I'm leaning toward zip ties. I didn't notice my inspection sticker expired in June. doh
#140
I appreciate this is mostly an American thread. Here in the UK went for a stick on plate, the same personal plate I had on my old X100
Not strictly legal but I've only had the police say it was fine, one even tried his speed gun on it and said it registered (despite being non-reflective {?)
For MOT all of the older MOT testers I use have kit cars and are quite forgiving
Old
New
Now if push came to shove I just carry a spare normal sized front plate in the car and some 3m command velcro, so if pulled over by police and warned I'd simply attach it.
Was quoted £100 by a mobile spraying service (Chipsaway) for filling the 6 (??) holes and refinishing, it won't be a flawless finish but will pass muster until next year will get the whole bumper off and resprayed
Old
New
