Heads up display HUD
Bought this one!
https://www.aliexpress.com/item/GEYI...192f4c4dIHwR6O I needed a reflector so took a membership card(blank credit card) and cut it a little to fit the HUD and bent it. Painted it grey metallic(only paint I had at homehttps://www.jaguarforum.com/images/s...icon_smile.gif) Took some black insulation tape to stick it to the HUD.https://www.jaguarforum.com/images/s...icon_smile.gif https://cimg7.ibsrv.net/gimg/www.jag...d17edef9a0.jpg https://cimg8.ibsrv.net/gimg/www.jag...c0a017539c.jpg It came along with a reflector sheet so you can see it better in daylight but I didn't need it as it's easy visible at day and not disturbingly strong at night. You can set a buzzer alarm for temperature and on my way to work yesterday the engine was around 93-94 degrees celsius. What temperature should I set for the buzzer to go off and warn me of high temp? Damn, I need to dust me car!:D |
Interesting.
Does this one actually turn off with the car? I have the Autool, but it only goes to sleep and my Cteck never goes green. |
Originally Posted by peterv8
(Post 2050655)
Bought this one!
That is pretty clever!
Originally Posted by old_dawg
(Post 2050690)
Interesting.
Nice work Peter.
Pity when I looked I never could find on using imperial measurements. C is not as good as F for me...
Originally Posted by Ranchero50
(Post 2051305)
This is awesome!
(Post 2051321)
You can change it to Fahrenheit if that's what you mean. :)
https://cimg4.ibsrv.net/gimg/www.jag...d478180fde.jpg
I just put it on dash Works great even on sunny days Highest temp I got yet was 95 C. Usual is 92 Is thar the engine sweet spot? |
(Post 2051878)
Are you sure? The description talks about changing the alarm temp below 120 but nothing about setting it up for `F versus `C.
I have ordered mine, so will be nice to know. But I can deal with it either way. If it registers anything over 95*C, I will be paying attention.
Seller finally answered my question, the one I have (A200) only displays Celsius.
Update!
The reflector I made of a plastic card didn't last, when summer came it flattened itself in the heat but found a piece of thin alloy sheet instead which won't react on heat!:-) |
I used this small Scangauge unit which turns off and on with the ignition. Comes up to the settings you select . I use it to read temperature and battery voltage but you can see the various options it will provide. I only wanted to read 2 functions and wanted it small enough that it doesn't obstruct anything. https://www.scangauge.com/products/scangauge-e/
Yours is the better unit but mine looks neater IMOO:-)
Where did you plug in the connector to get the coolant temp? I’m very interested in this too.
Originally Posted by badicedog
(Post 2091781)
