Help me identify the part - XK 4.2 NA - 2007
Hello forum,
Last week I bought an XK 4.2 from 2007 and today I got it on the lift at my friends place and we noticed that I have a small oil leak coming from this part: https://cimg4.ibsrv.net/gimg/www.jag...520481df57.jpg I guess this is an engine oil cooler but it seems that someone bypassed it. (I guess it was leaking coolant into oil system) Can someone please help me identify the part number so I can try to order a replacement unit. Thank you! |
:eek:
Sorry, couldn’t help it.
I ordered a spare a few years ago and this was the part number listed in the eBay ad: 6W83-6A642-AA |
Here’s the part listed on our forum sponsor’s web site:
https://cimg5.ibsrv.net/gimg/www.jag...344d88aa31.png |
Originally Posted by neven.gordic
(Post 2737242)
...... (I guess it was leaking coolant into oil system) .....
Graham |
Thanks a lot for the answers provided.
When I search for 6W83-6A642-AA it gives me a Ford part which is priced at around 80 euro. The one from Barratt is priced at 485 euro. :icon_eek: They both look the same on the pictures tho. Will give it a shot with the Ford part since it a lot cheaper.
Originally Posted by GGG
(Post 2737402)
Not necessarily leaking. The oil filter is awkward to remove without the correct fluted key and a PO could have done this to make it more accessible. Given the cost of a replacement cooler and that it's showing as out of stock at Jaguar, I'd reconnect it and see what happens. Just run it up to temperature and not embark on a cross country tour, of course. :icon_lol:
Graham In order to change this part out, I need to drain both oil and coolant, right? |
(Post 2737576)
..... When I search for 6W83-6A642-AA it gives me a Ford part which is priced at around 80 euro. The one from Barratt is priced at 485 euro. :icon_eek:
They both look the same on the pictures tho. Will give it a shot with the Ford part since it a lot cheaper. ..... https://www.ebay.co.uk/itm/163800454981 https://cimg8.ibsrv.net/gimg/www.jag...b58e45aaf3.jpg Worth investigating. An oil change is a given as you will be disconnecting the filter. Coolant loss can probably be limited by temporarily blanking the hoses but I'd take the opportunity to do a flush and refill. Graham |
Earlier this year car had an oil leak. I thought it was a failed gasket within the oil filter, or a coolant hose. But it turned out to be the oil cooler housing, once ordered part took approx. 8-10 days to arrive. Billet not plastic, there are two types. No leaks since (knock on wood)
