Lexol residue
#41
Um, so yeah, back to my question about using Lexol on the dashboard, too. I guess I have read it's fine. I'll report back in 10 years to let you know how it worked out for me. I appreciate all opinions. Just can't keep buying the next best thing all the time and leaving full bottles around the house. I probably wouldn't have bought Lexol without reading a lot about it first. It's just been a while.
Sov211/Gregory, experience does matter most to me.
GR
GR
robtroxel (08-01-2018)
#42
Used the Lexol conditioner on my 2010 after purchasing it with 4,800 miles on it. Biggest mistake I made. Left streaks on the passenger seat that to this day after over 4 years I cannot get out. I should have tried it on a inconspicuous spot first. My error. Regardless, my car stays in the garage and almost never sees the sun. Still smells new. Bottom line is I will not use the Lexol conditioner on any car again. I used it on my dash and the rest of the leather coverings without issue. The Lexol cleaner I have no problem with. Just my 2 cents.
The following 3 users liked this post by bocatrip:
#43
#44
If you really want to know if your conditioner actually soaks in or merely evaporates, do this:
Find an inconspicuous horizontal and flat spot of leather and apply a decent but not excessive amount of conditioner on it. Take a fairly adequate piece of clear plastic wrap and place it over the entire amount, trying to press the edges down well so nothing leaks out. Leave this alone for about 15-20 minutes, NOT IN THE SUN OR HEAT and then see how much remains. Compensate for any leakage or seepage and make your decision.
I've only seen any depletion doing the above procedure one time, and that was on dried and cracked leather on my old Mustang, and I could visibly see on the leather where it darkened just a bit where the worst of the wear was located, sort of spider-webbed-out. I did it again on a 'normal' appearing area and the whole amount remained and the appearance of the leather was retained, other than it was a bit cleaner than it had been. A quick wipe with the conditioner on the rest of the seat and everything matched instantly.
#45
The scent is by design and a lost art, distinctly British. (once reserved only for Rolls, I cant believe i have it in an affordable car)
Thats why its essential to not use any chemical that alters that unfavorably.
The Leather Masters products I use have no conflicting aroma to them, its as if Jaguar used the same thing, and in a way they did, as the coating on our leather is made by same Leather Masters.
Good to hear that even the convt has it.
GhostRider9000 (07-31-2018)
#46
#47
Assume you have tried the Lexol cleaner on these streaks? Or maybe some old fashioned saddle soap? If I had this situation, I think I would continue to put more Lexol on until the surface streaks were moderated. It might take many more coats but it makes sense if you think the product cause the steaking in the 1st place. All the best.
#48
mosesbotbol (08-01-2018)
#49
The "conditioners" that contain silicones (often thoseproduced by car wax companies) do not draw any of the dirt and salts to the surface and therefore they leave only a siliconed-smooth surface but they do nothing to "feed" the leather. Quite the reverse. They ensure that no conditioner can ever reach into the leather. But we all have our favourites. The question really is: how long do you want your leather to last without cracking: 5 years or decades?
robtroxel (08-03-2018)
#50
Your loyalty to Lexol is admirable as you find it works for you and has served you well for a long time. But, I don't like the product, it produces streaking and requires more work (buffing) to get the leather to look decent than other quality conditioners I've used. There are other products that I find easier to use with equal results and many others have experienced the same poor effects (which is why I changed to other conditioners). By all means if you like Lexol, keep using it to your heart's content, but don't for a minute assert that there aren't other equally proficient products out there that may, in fact, be preferable. Let's compare notes in 10 years and see if yours is better than mine. I'll still have my XKR, though I might not be able to still drive her.
#51
There are indeed other really excellent conditioners available (and I have mentioned a few of them in this thread); I am simply reporting (as you are) my experience with one of these products. And I will be happy to compare leathers in 10 years...my wife's X-Type, in daily use for 15 years, outside 24 hours a day, and which receives only nominal attention of any kind, gets a Lexol treatment about 3 times a year (my own cars get much better treatment in every way - and the garage space was negotiated years ago). All the leather in that X-Type, including that on the driver's seat, is virtually as new with no cracking of the surface, no dye scuffing, no dryness - this is just one real-life example. But we all have our preferences - which vary according to our experience. I think the thing we can agree on is that all automotive leather does need some conditioning to keep the coloured surface soft and supple and thereby prevent cracking and drying.
tberg (08-03-2018)
#52
#53
#54
Queen and Country (08-03-2018)
#56
Still Like New
My 2009 XKR is now 10 years old and, except for the driver's seat left side bolster and center arm rest, all the leather is still like new. As mentioned in my previous posts in this thread, I've been using Griot's leather conditioner for years to keep those surfaces clean and supple. I touched up the chafed driver's seat bolster and center arm rest with Dynamix dye and they look almost like new. With proper care, I think the leather interior will last at least another 10 years.
Of course, no one has ever sat in my rear seats. And my XKR has always been garaged.
#58
When I was younger and religiously used Leatherique (on the car) I did question them, that it seemed impossible for Leatherique to be absorbed by the leather. So the mickey mouse excuse they gave me was: it goes in through the stitching. Even then I questioned if that was the case you would end up with the leather around the stitching enlarged and softened long before the area you wanted to condition got any.
BTW, nearly all leather is sealed, but the older Rolls Royce and other exotics were not, that's where this whole idea of conditioning got started. There are others that are not sealed like the King Ranch seats, and look at what happens to them, sweat stains.
mosesbotbol (08-03-2018)
#59
P.S. Here's the link http://www.dynamixdyes.com/jaguar-le...dyes-182-c.asp
#60
