Power Window problem
My windows do not go down the 1/2 inch when I open the door. Is this a common problem, is there a fix I can do myself?
Thank you! |
Try to reset the windows as follows:
Turn on the ignition. Start with the windows up and doors closed. Lower both windows and keep holding the buttons for 5 seconds after the windows are down. Then raise the windows and keep holding the buttons for 5 seconds after the windows are up. If the problem resolves, then recurs again, your battery is probably low and needs a charge or replacement. |
Resolved!
Thank you WhiteXKR! That was easy, problem resolved.
