Radio has no sound every so often
Once in awhile when I start my car the radio will come on with no sound. The sound works with my cds or blue tooth streaming through a Bovee. The battery is new and car gets driven every day. Any thoughts?
Try a hard reset. Ive had this happen in my Rover once.
I have had it happen with my xkr using the ipod. The sound will cut out and after a few seconds the sound will come back. On the screen it says" check ipod connection". So I unplugged it and plugged the connection in again. Does this sound like I need a hard reset?
how do you perform a hard reset ? I know in German car you would hold the on/off button down until the radio powered off and after 20 seconds or so it would power back up.
The hard reset is a matter of disconnecting the battery leads, touching the two battery leads together for several seconds and then reconnecting the battery. This process restores all the modules to their original configuration.
Originally Posted by sov211
(Post 2661663)
a loose ipod cable connection has done this to me once or twice. my cable is just old, and the detents on the port/connector don't do as good a job as they used to.
