XKR exhaust tip - OEM upgrade anyone?
Hi
Anyone out there put the new OEM chrome tips onto a current XKR? Do they look better and are they any larger than standard XKR exhaust finishers? thanks |
did not know there was an optional tip. My '13 came with fairly big ones. Are there bigger and better ones? Bigger is always better!!!
Peter |
C217999 is the part number for new xkr tips
Hi Peter
the OEM part number is C2P17999 - around $400 I reckon from UK suppliers. Haven't got an answerback to a query about how much larger they are than stock tips yet. Cheers |
You can also look into aftermarket tips. I did magnaflow rolled tips on my Rover and looks much better than stock. Cut and weld is needed though.
2 Attachment(s)
Ghostrider,
So that's what happened to the Hurricane Sandy flood-damaged XKRs that were left out in the sun to dry! https://www.jaguarforums.com/forum/a...ine=1359324054 Thanks for a good laugh! :icon_lol: Stuart |
Oem tailpipe finisher did the trick
Got the oem quad tailpipe finisher from duckworth parts in uk. Look great, and finish off the rear view of the xkr nicely. Best of all they keep much cleaner than the stainless steel pipes as the black exhaust soot ends up hidden inside the fold in the new tips and is not visible externally. Add about 12 mm to the width of the pipes so are as large as can fit into rear space as possible. A worthwhile addition that finishes off the aesthetics nicely.
Originally Posted by POC62
(Post 708790)
Pictures please. |
4 Attachment(s)
Originally Posted by dgl
(Post 709418)
pictures please.
I like the looks, but sadly we 1st gen XK owners can't add them without a new rear valance (our openings only fit a single pipe passing through). Was looking at the Borlas as a possibility as well. Vince |
Vince,
A new XKR valance for 07 t0 10 cars is avail cheep.I was able to replace my XK valance with an XKR valance with little truoble. No paint, no cutting, just bolt it on. Perhaps the same solution is avail for you guys with later issue XKs? |
Originally Posted by tarhealcracker
(Post 709659)
Vince,
Yep, that sounds about right.
You may also cut a section out of the middle of your old XK valance and move the two ends toward the center. It requires some skill and leaves a cut seam in the middle that must be dealt with but you end up with perfectly formed exhaust openings for a quad system. But for $40 to $200, why fool around with that? |
Vince,
Where did you see the rear valance for $43!! That's crazy. Any chance you can share the link. thanks Steve |
Originally Posted by CleverName
(Post 710336)
Wow, $43 for an '07 XKR valance? Is that right? 2010s and up are over $200!
The 07 valence is black plastic, unpainted and relatively small. The 08 valence is a little larger and, I believe, painted (so it will come primed, something the factory charges you for). I then lost track on the year-by-year changes, but the 10+ have a relatively large (compared to 07 and 08) valence that is painted and has been reshaped. |
(Post 710497)
SJTYRER - Got the price from a parts breakdown list i have (printed in 2010). It may be what we call a "jobbers" price ( a discount offered profesionals in the repair industry), but you shoud be close to that when talking to any of our forum sponcers. for 2007 - 2009 XK, C2P2993, Extension, Lower Cover - $42.89 for 2007 - 2009 XKR, C2P8245, Extension, Lower Cover - $42.8 for 2010 - XK, C2P16680, Extension, Lower Cover - $222.50 for 2010 - XKR, C2P16656XXX Extension, Lower Cover, - $222.50 (paint to match) Vince |
Quad pipes
2 Attachment(s)
It is possible to fit twin (or quad pipes) to a first gen XKR. I see clever name was struggling earlier in the thread. These are the ones fitted to my 1999. They are made by adamesh, and are stainless And they make a great noiseAttachment 39607
They fit the standard hole with no cutting of the valance. |
(Post 708790)
