XKR Lowered H&R Suspension
https://cimg6.ibsrv.net/gimg/www.jag...5115bba89c.jpg
https://cimg7.ibsrv.net/gimg/www.jag...6769e6a1f7.jpg https://cimg8.ibsrv.net/gimg/www.jag...0eb41f36fb.jpg https://cimg9.ibsrv.net/gimg/www.jag...728d99863a.jpg Lowered my 2014 XKR over the weekend, might not be everybody's look. I think it looks nice and aggressive. |
Looks badass!
Looks really good!
I'm thinking of lowering mine but maybe not as much as yours, half an inch less I would like .:-) |
2 Attachment(s)
Pete go the Spires eibach 20mm lowering, the handling difference from the standard xk spring to the performance springs is exceptional.
Thanks, the H&R states it lowers 1.3 of an inch, Seems more. I also put the wheel spacers on, pushed out the wheels.
Too low for me. But each to his/her own. I would never get out the street that low!
Originally Posted by Freedom8675
(Post 1758180)
I feel the rear looks to be sitting almost lower than the front, it would look better with a small rake ankle the other way.
Have you considered changing the red brake caliper covers to black? |
Originally Posted by makecopies
(Post 1758338)
With some spacers it will be perfect!!
Originally Posted by Tervuren
(Post 1758339)
Have you considered changing the red brake caliper covers to black? Thanks |
(Post 1758349)
Not a bad idea in black, I install the red, might be a bit much. I think black would look clean
Thanks 20mm spacers are perfect for the front, but 15mm is the limit on the rear I believe.:icon_wink: |
running the same set up and it's perfect in all ways.
Originally Posted by Jockster
(Post 1758361)
No way, red is loads better, links up with the rear light cluster and draws your eye around the car.
20mm spacers are perfect for the front, but 15mm is the limit on the rear I believe.:icon_wink: Where to buy? |
Originally Posted by peterv8
(Post 1759115)
What kind och spacers do you use?
Where to buy? |
I'd consider spacers on the rear, but on the front they'd mess up the Scrub Radius.... and other geometry.
How do you drive over railroad tracks and parking lot speed bumps in a car this low? Also, how do you turn sharply at speed without rubbing front fender?
Originally Posted by Cee Jay
(Post 1762240)
Does not rub at all in the front, I did get a bit of rubbing in the rear when taking a turn quickly. I had them "roll" the inside fender a bit and it went away. As for speed bumps, I go over slowly, otherwise I can bounce on top of them.
I get all kinds of looks in the car, it looks great |
(Post 1758178)
I have lowered a couple of Alfa Romeo's in my days and wonder if an XK is DIY?
Any special tools needed? Is it a pain to get them off and on? |
