Door card repair
Old May 18, 2013 | 03:35 PM
RaceDiagnostics's Avatar
Default Door card repair
My drivers door car has been loose at the top back corner since I got the car, I thought I would just have to live with it till I found the post on the replacement clip by "The Coupe".
The palstic insert had broken at some point in the past, I am not sure what the point of the cable tie is.
The new clip is available from Jag.
I marked the position and then removed the old clip with a flexible knife.
The clip came off no problem.
I used 2 part epoxy glue to stick the new clip on.
Clamped for 24 hours.
Attached Thumbnails Door card repair-doorclip1.jpg   Door card repair-doorclip2.jpg   Door card repair-doorclip3.jpg   Door card repair-doorclip5.jpg   Door card repair-doorclip4.jpg
Old May 18, 2013 | 03:48 PM
Davebc's Avatar
Nice job, did same clip on my drivers door!Previous owner had used tape (clear) to hold the card in place~yuk
Good to see Araldite still kicking, haven't seen it since I lived in Luton lol!
Old May 18, 2013 | 05:18 PM
GordoCatCar's Avatar
Did the same epoxy fix on the same post in the door 'card'*. I also added four 3" x 8" strips of dynamat on the inside of the door skin. Also used a zip tie to hold down the long rod running from the inside door handle to the latch mechanism. Anything that rattled got muffled, tied down or wrapped.
*Wheeler Dealer speak
99xk8guy
Sep 29, 2025 10:51 PM
H20boy
Dec 24, 2024 03:23 PM
kevinl
Oct 31, 2019 06:15 PM
UalCapt
Sep 14, 2015 01:42 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
