Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XK8 / XKR ( X100 ) (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/)
-   -   03 XKR Driver side heat shield C2N1200 needed. (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/03-xkr-driver-side-heat-shield-c2n1200-needed-157857/)
ET1 Feb 15, 2016 12:30 AM
Anyone have one available?
I've tried multiple dealers and two wreckers to no avail. All say it is discontinued.
Gaudin parts guy didn't have one and checked stock in UK from all his sources and none available there either. TIA
woox4 Feb 15, 2016 02:29 AM
A few more options for you to try.
SNG Barratt - The Ultimate Jaguar Parts Specialist
Jaguar Partno_C2N1200_HEATSHIELD-E_David Manners Group
Jaguar X100 Exhaust Manifold Heatshield - LH B-bank (C2N1200-HP) - JustJagsUK.com
Jaguar Genuine Part Number C2N1200 | Heatshield-Exh M
You'll be able to get better help if you add your location to your profile and your car details in your signature.
tassiejag Feb 15, 2016 03:25 AM
I think this is the heatshield that sits under the header tank for the radiator on the left hand side of the engine (the passenger side down here in Aus)? This heatshield on my XKR disintegrated when the gearbox was being removed and a replacement could not be sourced here in Australia or from the UK so the independent I use made one out of stainless and it works fine. This may be a cost effective solution for you if you know a good independent Jag specialist.
GGG Feb 15, 2016 04:10 AM
1 Attachment(s)
Several suppliers list C2N1200 but show zero stock. The only one I can find with stock is JustJags in the UK:
Attachment 125525
Note they are showing only 1 available.
ET1 Feb 15, 2016 02:16 PM
Originally Posted by woox4 (Post 1403015)
Thanks Chris, Tried them all, no luck so far and updated my profile as well. This thing is like a unicorn!
ET1 Feb 15, 2016 02:18 PM
Attachment 125525
Thanks Graham, No response from them yet, as it is after hours across the pond.
wolfpck1 Feb 15, 2016 07:51 PM
don't run it without the heat shield it can cause the trans cooler lines to deteriorate .
julesjag1 Feb 17, 2016 07:51 PM
I probably have one in my "stock". If you can send me a pic or diagram I will find it for you. If they were installed on the 2000 XKR's I have it.
Neil
ET1 Feb 18, 2016 04:30 PM
Available heat shield.
Neil
Hi Neil,
I finally reached the guys at Myton Automotive in the UK and ordered, what I think, is the last retail one
for sale yesterday, right before I got your message.
Thanks for the offer.
I would gladly have bought yours otherwise.
Evan
03 XKR
SF Bay Area
julesjag1 Feb 19, 2016 08:00 AM
No worries, keep me in mind if you need anything else.
Thanks, Neil
Cdubu Sep 6, 2016 07:43 AM
Does anyone have availability for this heat shield, still? I have calls into various places but no one has been able to locate one as of yet.
BobRoy Sep 6, 2016 08:37 AM
I have 2 parts cars. I have a 99 with engine out. I won't be to my shop until tomorrow. I'll check on condition then.
Cdubu Sep 6, 2016 10:10 AM
BobRoy,
Thanks, let me know.
BobRoy Sep 7, 2016 06:03 PM
That shield as far as I can tell it only on SC engines. All of my XK8 are N/A. I saw it at terrysjag.
dsnyder586 Sep 8, 2016 09:11 AM
They are on all cars, but in order to get to the O2 sensor they have to be removed and are a PAIN so usually not put back on. Am debating putting one on the coupe as it is a nice example of a car in original condition.
© 2026 MH Sub I, LLC dba Internet Brands
