1998 XK8 front Struts, should I replace with new or used?
Old Apr 4, 2018 | 03:24 PM
caliau's Avatar
Default 1998 XK8 front Struts, should I replace with new or used?
My front left strut is leaking and I feel and hear bumps. I am wondering if ok to buy used front struts or buy new.
If used, any pointers for telling if the strut is in good condition?
If new, any suggestions for low to regular priced struts?
Old Apr 4, 2018 | 06:29 PM
Ungn's Avatar
They are not struts, they are shocks and are only about $120/side shipped, including new Bellows and bump stops.
Also likely needed are new shock mounts, which are the crumbly orange foam underneath the black cap at the top shock nut. These are about $150/pair off Ebay.
Old Apr 4, 2018 | 06:51 PM
RJ237's Avatar
+1. Stay with the Bilstein shocks and get the black urethane mounts from Welsh Ent. Also replace the sway bar mounts and drop links, not expensive.
Inspect the upper wishbone bushings, they are probably shot.
Old Apr 4, 2018 | 11:03 PM
XK8 Comfort's Avatar
You will be happy if you replace the shocks and the mounts. Well worth the time and effort.
Old Apr 5, 2018 | 03:45 PM
caliau's Avatar
Thanks everyone for your input, much appreciated.
I'll follow up after I disassemble, inspect and replace.
Old May 24, 2018 | 02:52 PM
caliau's Avatar
Thumbs up
Thanks for the advice everyone,
New shock mounts, shocks bump mounts and reused bellows. After an alignment running smooth as new.
mjm3457
Dec 16, 2021 04:14 PM
TPBachur
Oct 3, 2016 12:04 PM
bojangles
Jul 11, 2007 08:56 PM
SonicRiot
May 24, 2007 11:32 AM
SonicRiot
May 20, 2007 08:04 PM
