1999 XK8 Paint
My '99 XK8 coupe still sports her original paint in good condition. She was obviously kept out of the sun since the Phoenix Red color is still bright and matches the inside painted areas well, e.g., inside trunk lid. However, there are ten or so spots on the body that look as though an unfriendly bird may have bombed her and the droppings weren't wiped off. They vary in size from 1/4 inch to 1 1/2 inches and are irregular in shape. They cannot be felt and are only noticeable in certain light.
I want to retain the original paint, so a respray is not an option. I have waxed her several times but no joy: the spots remain. Did Jaguar use a color and clear coat paint on '99 XK8s? Would a careful clay bar application likely help or might that damage the finish? I drive her frequently and don't want a concours finish, but the spots bug me. I will appreciate any thoughts on how I might remove them. |
I have had good success removing residue spots (including hardened pine tree tar and bird sh!t) on automotive paint with rubbing alcohol, an old cotton diaper, and some very careful but sustained elbow grease. Have you tried this approach?
Bird poo can be very acidic and will eat through the clear coat in less than 24 hours.
I've had good results by GENTLY rubbing the offending area with toothpaste (mild abrasive) to feather the edges and then follow with polish and then wax. If the toothpaste isn't abrasive enough, then you'll need to use the finest wet & dry sandpaper (use wet) available, followed by the polish and wax. The bird poo normally does not eat entirely through the clear coat if caught in time. It's only when left for days/weeks that it eats through to the base coat. The key word here is GENTLY! Cheers, Stu |
a good auto body painter can spot repair and blend the clear coat.
Originally Posted by jimmiejag
(Post 1860670)
I want to retain the original paint, so a respray is not an option. I have waxed her several times but no joy: the spots remain. Did Jaguar use a color and clear coat paint on '99 XK8s? Would a careful clay bar application likely help or might that damage the finish? I drive her frequently and don't want a concours finish, but the spots bug me. I will appreciate any thoughts on how I might remove them. Yes, the 99 has base/clearcoat Unless the spots are left over residue a claybar will not remove them. As a guess and it was already mentioned that the clear coat is etched. Your fingers will not find very tiny imperfections. Without actually seeing them, my best guess is the spots need to be compounded, then polished. Go to your local auto parts store and get Meguiar's Ultimate Compound, you can use it by hand if you don't have a buffer and a cutting pad. If by hand use medium type pressure and work the product after a minute or two, gently ease up on the pressure while still working the product. Work until it is almost gone. This product has what they call diminishing abrasives. The compound starts out as big chunks(relatively speaking), which removes the etchings, and as you work it, it breaks down into a very fine abrasive/polish as you ease up and breakdown the product, it will polish up the surface to a nice shine. If they do not disappear then they need to be buffed or wet sanded out. |
Originally Posted by WhiteHat
(Post 1861153)
If the car is in good condition, a X100 definitely deserves being brought back to flawless state. :) |
Thanks for the replies. I will try the toothpaste method first, followed by compound then fine sandpaper. If none of those work, I will try a good body shop. While the bird crap spots aren't terrible, they are a distraction from a near perfect finish.
Originally Posted by Jeagar
(Post 1862759)
This is in my opinion the best suggestion. Get a quote from a pro shop. It might be reasonable and you will get it perfect again. :icon_wink:
If the car is in good condition, a X100 definitely deserves being brought back to flawless state. :) Wow! Auto paint shops must be dirt cheap in your area. Since bird droppings, tree droppings, acid rain, etc., are a recurring problems, how often (in your opinion) should the OP have the clear coat resprayed/repaired by a pro shop? Every three months, six months, twelve months? Do you think it would be better to have a professional painter on a retainer or just to list him as a dependent on ones income tax return? I'm always amazed at how easy it is to spend someone else's money. This is a DIY repair. It's called paint correction. Stu |
Originally Posted by StuG
(Post 1863101)
Since bird droppings, tree droppings, acid rain, etc., are a recurring problems, how often (in your opinion) should the OP have the clear coat resprayed/repaired by a pro shop? Every three months, six months, twelve months? Do you think it would be better to have a professional painter on a retainer or just to list him as a dependent on ones income tax return? I'm always amazed at how easy it is to spend some else's money. This is a DIY repair. It's called paint correction. Stu I said get a quote. Sometimes you think it's a lot of money and it's not. I'm not sure his car needs the clear coat resprayed. I once had what I thought were deep scratches on my paint and I took it to a shop to get a quote, expecting it would probably be too expensive. I was so surprised by how affordable it was that I left the car right there to have it done and took a taxi home. Doesn't hurt to ask.:icon_wink: Oh, and it might be a good idea to lay off the caffeine. It might give you a stroke.:icon_tongue: Overreacting much are we? :icon_mrgreen: |
(Post 1863084)
Hi Jim, Please get back to us and let us know what works/worked for you. Cheers, Stu |
(Post 1863108)
Maybe I just think the car deserves whatever price it is to bring it back to perfection? I really like the X100. I'm not getting into it because I can't afford a X150 or some other similar car. It's because I truly like the car. Gorgeous! :)
I said get a quote. Sometimes you think it's a lot of money and it's not. I'm not sure his car needs the clear coat resprayed. I once had what I thought were deep scratches on my paint and I took it to a shop to get a quote, expecting it would probably be too expensive. I was so surprised by how affordable it was that I left the car right there to have it done and took a taxi home. Doesn't hurt to ask.:icon_wink: Oh, and it might be a good idea to lay off the caffeine. It might give you a stroke.:icon_tongue: Overreacting much are we? :icon_mrgreen: In fact I have a Model S coming in and I quoted her $250 - $350 to remove all the bird etchings just on the hood, if she wants a ceramic coating put on, then it will be $650. She told me a quote to sand and reclear the hood, was $1500, which was no surprise to me at all and did not include putting a ceramic coating on the hood. So let's see where the OP finally solves the problem |
Jim,
I went out to YouTube and found a number of fearturettes on the fine art of bird crap removal. Find one that makes sense to you and give it a try. |
Thanks for all the ideas. Unfortunately, Spring isn't happening here in the Midwest US. It was 29 degree F this morning and, just to add a degree of difficulty, our electrical power went out last night when a branch snapped off and pulled our supply line down. Just replaced the line this morning. So, I've not had a chance yet to try the toothpaste/compound fixes.
I will post when Mother Nature gets her act together. Global warming? |
Some Positive Results Removing Bird Crap Residue from Paint
As noted, I finally got a break in the weather here and tried the toothpaste method to remove the effects of bird poo on my coupe. The results were that some of the marks were reduced, but it took quite a bit of work. So I next tried a mild polishing compound, just a step below rubbing compound in "gritiness", and the results were good. I have reduced several of the most noticeable spots and am sure that more time and elbow grease will produce a good result.
Thanks for the replies! |
