98 Transmission into 97??
Will a transmission from a 98 XK8 (or XJ8) work in a 97 XK8???
The wiring diagrams from the electrical guides seem to be identical..... Does anyone know for sure?? |
Hi ,
A 98MY XK8 transmission will definitely fit a 97MY XK8 , not sure about an XJ8 though , Hope this helps , Nik |
ALL 5HP24 gearboxes will work in ALL 4.0 V8 XJ/XK cars!!!!!!!!!!!!!!!!!!!!!!!!!!
You just need to use the rotary switches on the selector shaft because the part numbers are different and I don't know if they will exchange!!!! (I have not tried that) The internal harnesses have different part numbers but it does NOT make a difference as I have installed a late gearbox in an early car and the other way around!!! bob gauff |
