98 Transmission into 97??
Old May 19, 2012 | 09:21 AM
XJsc-guy's Avatar
Default 98 Transmission into 97??
Will a transmission from a 98 XK8 (or XJ8) work in a 97 XK8???
The wiring diagrams from the electrical guides seem to be identical.....
Does anyone know for sure??
Old May 21, 2012 | 03:54 PM
NikasilNik's Avatar
Hi ,
A 98MY XK8 transmission will definitely fit a 97MY XK8 ,
not sure about an XJ8 though ,
Hope this helps ,
Nik
Old May 21, 2012 | 10:12 PM
motorcarman's Avatar
ALL 5HP24 gearboxes will work in ALL 4.0 V8 XJ/XK cars!!!!!!!!!!!!!!!!!!!!!!!!!!
You just need to use the rotary switches on the selector shaft because the part numbers are different and I don't know if they will exchange!!!! (I have not tried that)
The internal harnesses have different part numbers but it does NOT make a difference as I have installed a late gearbox in an early car and the other way around!!!
bob gauff
Poet
Feb 7, 2025 02:18 PM
Marka
22
Sep 11, 2016 12:09 AM
dmatthewman
Sep 30, 2015 10:10 AM
Old_Doc
Sep 29, 2015 03:43 PM
