Anyone - XKR adamesh exhaust system
Hi,
I thinking about this set to my XKR. Jaguar XK8 & XKR Sports Exhaust System | eBay Has anyone fitted this set and got sound file ? |
i asked this same question - the reply recommended getting the upgraded air filter at the same time ;)
Originally Posted by LondonXK8Boy
(Post 1047854)
Thanks. I already changed the air filter to K&N |
They're highly recommended in the UK, lots of XKEC members have them, if that helps. They do an over-axle system too, for another couple of hundred iirc.
Note that stainlessteelexhausts.com will do the overaxle + straight throughs for £350 total |
My local garage did stainless back pipes and a pair of nice tips for £100 all in .
See if this works......
Originally Posted by Artek
(Post 1047829)
Hi,
I thinking about this set to my XKR. Jaguar XK8 & XKR Sports Exhaust System | eBay Has anyone fitted this set and got sound file ? I still have them in perfect shape and are selling them for a good price. If you're interested send me a PM (need to check if the are fitting I do have a 2001 XK8). Cheers, Nicolas |
Devspider has the best setup. Remove the central muffler and the two muffler eyes, keep the over the axles pipes, use Magnaflows for the rears.
Rear muffler deletes are not better. And dismiss the nonsense about how the over the axle crimped pipes reducing performance , they don't. Straight pipe with those things in place and no rear mufflers and your xkr low end torques is substantially, very noticeably reduced. $300 in labor and $200 parts and you can get Devapider setup. If only I had known up front in my own exhaust ventures... |
1 Attachment(s)
I received my JAG.
Attachment 157092 The sound is awesome but one thing bothers me. Sound on 2.000 rpm in the long run can be disruptive. Occurs exactly on 2.000 rpm then disappears. |
