Bill B
Continuing on with my intermittent gearbox ECU problem is there a wiring diagram available in order that I try to locate how the ECU is earthed.
The impression is of a dry joint that with maximum voltage works but will drop out as the mood takes it.
New battery fitted not much different.could this also be an ignition key problem? any thoughts appreciated.
Regards Bill
Regards Bill
You can download the full JTIS (Jaguar Technical Information System) Workshop Manual from the thread in General Tech Help or just the XK8 Electrical Guide for your Model Year from my MediaFire account:
http://www.mediafire.com/view/yifkya...-JVK1997EN.pdf
It's a 5.4mB PDF.
It's a 5.4mB PDF.
