Brembo bleed nipple sheared!
Just sheared a bleed nipple off on a Brembo XKR caliper. It is pretty much level with the caliper now. Any good tips on how to get it out?
That sucks. I've always been a little afraid of that happening when I have worked on my own brakes. Especially the first time, that sucker was in there tight.
I know you won't have a Sears but you'll get the idea. Probably need something like: Easy Out Since the nipple is already hollow you shouldn't need to drill it even. If you have a machinist friend, you can ask them for advice too. |
1 Attachment(s)
Snapped a picture of the mess...
1 minute job with an easy out - a reverse threaded screw...
There appears sufficient protruding to be able to cut a slot in it and use a manual impact screwdriver.
http://upload.wikimedia.org/wikipedi...erWithBits.png The visible thread is rusted and a good pre-soak with penetrating oil has to help. I'd normally apply heat to free a seized bolt or stud but that would damage the silver finish on the caliper. Graham |
