Changing door speakers
Both door speakers in my XK8 convertible are dead. Do I have to remove the door panels to replace them, or are the grilles removable? Checked several threads and got contradictory information.
Thanks! |
There are two screws in the bottom of the grill and the will come out. Might be a little fiddly to get off but once removed should give you access to replace the speakers.
It has been a while but if I recall the best way is to rotate the forward part down and then unhook the rear tab. Reverse to reinstall. |
Sounds simple enough;thanks Charlie.
