Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XK8 / XKR ( X100 ) (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/)
-   -   Changing Front Engine Mounts (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/changing-front-engine-mounts-289507/)
daro31 May 7, 2025 10:02 AM
Are there any instructions for changing front motor mounts? 2000 XK8 Convertible.
https://cimg5.ibsrv.net/gimg/www.jag...d27f78605.jpeg
My buddies 2000 XK8 needs the front engine mounts changed, one is leaking the other is collapsed and dry as a bone.
I have found several right ups on changing the rear mounts but nothing for the front. They look fairly straight forward but I always like to check ahead for and suggestions that you experts can suggest.
bladerunner919 May 7, 2025 10:43 AM
Easy - support the engine, undo the bolts, lift engine a bit, swap mounts, lower engine, install bolts.
giandanielxk8 May 7, 2025 11:46 AM
Those are not the engine mounts, those are the front subframe mounts. It's significantly more complicated. You will have to drop the subframe. And those don't contain fluid. What you're seeing is a motor oil leak, possibly from the timing cover or the harmonic balancer seal.
baxtor May 7, 2025 05:48 PM
As Gian stated, front crossmember bushes.
l replaced mine several years ago, with crossmember in place, it can be done but would consider dropping the front end if doing the job again. they originally had a plastic body which makes it possible to "dig" them out with sharp chisel.
​#2 in pic. Part # MJA2370AJ
https://cimg1.ibsrv.net/gimg/www.jag...13de1dce4b.jpg
Hell-Cat May 7, 2025 07:30 PM
290 pounds sterling each ??? That is insane, though that does include VAT....
Even Lamborghini charge less than 80 pounds for their equivalent part.
Small wonder that Jaguar went down the pan.
giandanielxk8 May 7, 2025 08:39 PM
Yeah, the upcharge is insane for what is essentially a bush. I bought them from SNG Barratt, but don't remember paying anywhere near that amount. I don't think I went with the OE because of the price. I haven't had a problem with them in the past 3 years since I replaced them.
michaelh May 8, 2025 07:14 AM
I've no idea what is going on with Heritage. I have the receipt here for the ones I bought from the local dealership (albeit April 2022) which amounts to £90.13 / $120.41) for the two.
daro31 May 8, 2025 08:53 AM
Thank you for the information it is significantly better to find that out.
Hell-Cat May 8, 2025 09:15 AM
SNG Barrett USA are listing that part at $407 each (or $55 for a MaitaiHoPong after market part) , I'll schedule a kidney broker appointment before I do that job.
wymjym May 8, 2025 01:23 PM
ÜRO PARTS MNC7500AB
$72 usd @ at Rock Auto
wj
robak May 8, 2025 04:13 PM
hey guys. i know we get them from a good aftermarket company. i changed mine as the frame was out and i thinkni took „meyle“. i can look that up if you need the brand.
only for the engine mounts i had to stick with uro…
baxtor May 8, 2025 04:20 PM
Originally Posted by wymjym (Post 2842932)
ÜRO PARTS MNC7500AB
wj
But the engine mount is not the part he actually needs.
wymjym May 10, 2025 09:09 AM
I missed that point, need to read closer.
wj
© 2026 MH Sub I, LLC dba Internet Brands
