cylinder numbering
Got a P0351 on wife's XK8; which is B bank (drivers side US) but can't find which cyl is #5 on my JTIS. Found bank location OK; is it the front one or the rear?
Also what's resistance range for coils..........
Thanks Adrian
Thanks Adrian
Oh, depends on year! Only Jaguar would change the numbering system. In our case for a 2000 it's left front. Still need coil resistance ranges........................could not find them on SEARCH.
Thanks, Adrian
Thanks, Adrian
To check for a bad coil swap it with a good one on a different cylinder and see if the misfire code read on your OBDII reader follows the suspect bad coil.
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
Sep 26, 2015 07:04 PM
