Does 1997 xk8 have a transponder ignition key
Hello all. I just bought a baby blue 1997 xk8 conv for my wife as a Mother's Day present. Naturally it came with one ignition key, tibbe type, 8x3. Can anyone confirm yea or nay if the key has a transponder chip? The web info is published both ways so not definitive. Thank you very much, Bob G
Originally Posted by Robert Grisar
(Post 1682023)
For Rest Of World Cars, a Transponder is shown., |
Originally Posted by Paul Pavlik
(Post 1682055)
The 1997 Electrical Drawing Set does NOT show the Key Transponder Module for the North American Cars.
I was surprised when I went to the dealer about five years ago to get a key made and the bill was less than $45.
1 Attachment(s)
If you look very carefully at the key, you should be able to see where, if there is one, the transponder is inserted.
Attachment 150214 Not the best photograph in the world, but you can just make out the shape of the plug that covers the hole. |
Originally Posted by DevonDavid
(Post 1682276)
http://i773.photobucket.com/albums/y...psq7hgj4ka.jpg Not the best photograph in the world, but you can just make out the shape of the plug that covers the hole. |
I was unclear if the '97 had a transponder key or not, so I ordered a $20 cut key off Ebay, figuring I can use if for an emergency door or trunk key and danged if the car didn't start right up.
If you have to live with the issues of an early car, its great not to have to deal with the hassles of the later cars. |
. . . and also Bob, the answers to a few questions you have not asked, but which you should attend to asap . . .
:icon_toast: Ken |
Hello all. I'm still learning. My 1997 Jaguar XK8 did not come with a FOB. Can anyone tell me if the car is wired to accept signals from a properly programmed FOB? Thanks in advance of your learned answer. Very respectfully, Bob G.
Others may add to or contradict what follows because things are different according to year of manufacture, country sold, legislation etc but ...............
Early UK cars have a small transponder in the key. This must be programmed to the car by someone with the necessary Jaguar technology. Early US cars (and some other markets where car theft was not such an issue) don't have transponder keys. If the key(s) are original, then it's possible to see the small plug on the key where the transponder was inserted. The car is programmed to the key - not vice versa and the default is 5 different keys maximum. However, if you have one good key, it is possible to "clone" it with an identical transponder - in other words, the car can't tell the difference between one key and the other and thinks they are both "Key 1". If you get a "new" key from Jaguar, they will programme it into the car as "Key 2" rather than another "key 1". The metal bit of the key can be cut by any competent locksmith and, if you don't have a transponder, will work 100% OK Although some of the functions are "interconnected", the key fob is a separate piece of kit. Different countries used different frequencies, and there are variations between years but - if you buy an identically numbered key-fob on Ebay (for example), it should be possible to programme it to the car yourself. It's a bit hit-and-miss and although some owners have had no problems at all, others have had to resort to strange rituals involving the sacrifice of chickens and standing on one leg with both car doors open whilst trying to hear an inaudible "beep". |
I reckon David gets the Golden Underpants Award for top post on this issue - especially highlighting the variances not only between model years, but also between different markets. Somewhat like radio access codes (or not) the whole issue of keys, transponders and/or fobs is important to nail for your MY, variant and market.
It may well be (and I suspect is for the early cars) much easier and cheaper to acquire a 2nd and 3rd key without all the hassles imposed by the later cars' programming needs . . . but only if acquired now . . . before the single key is lost or mislaid. Best wishes, :icon_toast: Ken |
Ken. I'm flattered. The award .............. do I frame it and put it on the wall, or do I have to wear it ??
(Post 1682458)
You need a LJA2610AA Fob. FCC ID: K8597T315 Type in K8597T315 into Ebay to see your options. They are usually $50-$75 shipped on Ebay for a used one. If you have a working key and a working turn signal stalk, you can program the fobs pretty easily in the comfort of your garage using the procedure outlined in the stickies. |
My '97 Key looks original and has the "plug" and may have a transponder in the key, but the car doesn't need a transponder key to start. A lot of the confusion that US '97 owners have stems from the "look for the plug" in the key meme... "plug in the key, check"
20 years after production, whether or not the car has "transponder key" or not doesn't necessarily point to the car having a transponder set up. If its a US '97, the odds are pretty good it will start without programing for a transponder key. |
I'm very happy to be corrected - there seem to be so many variations with the security systems over the years / markets and everything adds to the "collective knowledge".
(Post 1683094)
I could take it to work and X-ray it to know for sure. |
Oops wrong post.sorry
the key that you have might have been purchased at a later date from a dealer. perhaps all of the blanks have a place for the transponder and one present, but it is the car's particular option that determines if it is necessary. maybe when the car was brand new the keys provided from the factory did not have a transponder pocket. in later years when the transponder became universal, they stopped making the old style keys and simply retained a common blank. this will be fun years from now if these cars ever get to the level of restoration where a judge looks at a first year car's keys to see if the key does not have a transponder pocket.
when i purchased some keys for my car from the local dealer, the vin gave them all of the information needed to cut the physical key, interesting. i then had to register it with the car. |
My '97 came with 1 FOB and 2 black keys. One key has the plug the other doesn't. Both keys work.
SOLVED
Hello all. Thanks to the many learned and helpful contributors to the Jaguar Forums, I went ahead and ordered a non-transponder key cut by triple-c.com. Cathy is the point of contact. The key arrived this morning and WORKED PERFECTLY. In summary, my 97 XK8 does NOT require a transponder key. It only required a Tibbe key. Cost $38.95 and 4 days, delivered by USPS.
