ECM replacement for a 2003 XK8
Old Sep 29, 2024 | 09:28 AM
Pantera928's Avatar
Default ECM replacement for a 2003 XK8
I have heard it said that if you replace the ECM with one that even has the exact same part number, that you have to get the ECM reprogrammed due to the immobilizer/key not being recognized.
If this is true, any recommendations for who can do do this.?
Also, doe the immobilizer prevent the car from even turning over on the starter or just prevent it from firing?
Old Sep 29, 2024 | 10:26 AM
michaelh's Avatar
It's more complicated on the 4.2. Even if the part #s match, it will need to be reconfigured. See this thread:
https://www.jaguarforums.com/forum/x...5/#post2494869
IIRC the car won't crank until this is completed, and note this procedure will break the existing ECM's 'relationship' with the car (i.e. you can't just put the old one back)
Old Oct 2, 2024 | 09:38 PM
zray's Avatar
the ECM topics are really scary. And I thought re-soldering the ABS box pins was tricky (naive, huh ?)
I’ll be doubly happy I have a 4.0 if I ever have to go down the ECM replacement road. Knock on wood.
Old Oct 3, 2024 | 02:29 AM
xalty's Avatar
not a big deal. program cluster as new, pats id gets transferred car will start, been there done that. if you have comms with the old ECM save its VID block and put it in after
ocwolfy
Sep 30, 2025 06:54 PM
wscott
Sep 18, 2024 11:43 PM
BillShipman
Mar 15, 2021 08:12 AM
CaptRick
Aug 29, 2020 08:59 PM
BobRoy
Apr 12, 2016 05:56 PM
