Can anyone help me identify the Keyfob antenna location on my XKR, 2002 convertible? I know it is above the rear window on the coupe but i don't even know what it looks like!
Thank you!
Thank you!
avern1
close
- Join DateMay 2012
- LocationWinchester, CA
Liked:1,328 Times in 1,006 Posts
It I believe is in the centered below the lower portion of the window. It should be accessed by removing the forward trunk liner.
WhiteXKR
close
- Join DateApr 2010
- LocationArlington VA USA
Liked:3,019 Times in 2,141 Posts
On the convertible it is under the right cushioned rear bolster (that has the snap for the tonneau cover, beside the stowed convertible top when it is down). It is a wire antenna. The coax connector for this antenna terminates at the security module under the trunk (Boot) fuse box. It is not under the window on the convertible. Avern1, I believe it is the GPS antenna that is under the window.
avern1
close
- Join DateMay 2012
You are correct WhiteXKR, my bad.
Vern
Vern
