Originally Posted by TC Johnson
(Post 970098)
One question I have is concerning evidence of Nikasil issues. The car has 93k, and clearly still has the original engine. Should I see something in the cylinders that shows that specific problem? I would have thought it would have raised itself before that mileage.
The conventional wisdom is if a nikasil engine has made it this far, it should be OK. Gasoline composition was the issue back then and now we have different blends. |
Resistance turning the crank
Thanks for the response. I won't worry too much about Nikasil issues, then.
However, I was reading another post from someone encountering a locked up engine, and one of the posts talked about being able to turn over the engine with a 3/8 stubby wrench. My engine takes a strong pull on a 24" breaker bar to rotate the crank. I just assumed this was a normal function of all the bearings and 8 pistons moving in the bores. Should I actually be concerned about this? There was talk of bottom end issues with this car. I have squirted oil in the bores to keep thigs a bit lubed, but now I wonder about more problems. TC |
