Very clean repair! My solution was a square access hole cut with a hand grinder, filed sharp edges and covered with a screwed on metal plate. Replaced both pumps on my XKR, they feed the same line. Relays in boot can be shorted to test pump operation, when both fail..no go. Note: grinder cutting showers sparks so remove rear seat and shield exposed surfaces with cardboard.
This string is a good reminder. I want to just cut the hole in anticipation of the day my pump will go. I am amazed amazed that the members who found mechanism to replace the pump for $120. I assure you they are not from around here ;-). I was going to ask for specific measurements but the photos give enough to use dead reckoning.
Anyone know how thick the sheet metal is ? I ask as is plan the method of attack. I do have a small nibbler, it is probably best if if just plan to use an 8.5 inch hole saw attachment for my drill. |
Originally Posted by Johnken
(Post 1574579)
Thanks to all for the Great advise . I will try these first before pulling the tank to change fuel pump. A VERY BIG THANK TO ALL OF U. bry549
Originally Posted by RDMinor
(Post 1434406)
The early Mustangs were just Falcon chassis with a sporty body bolted to the frame ......."
admittedly this is nit-picking, but the first generation Mustangs did not have a body that bolted to a frame, sporty or otherwise. It was a unibody car with bolt on front fenders and bolt on hood. The rest of the body was welded onto the frame rails and floor pan. No separate frame. There are few interchangeable chassis parts between the Falcon and the Mustang. Engine and driveline parts, yes, chassis parts , no. One question, How much time is saved by drilling an access hole to reveal the fuel pump(s) vs. just taking the tank off. I do understand the OP was going to be doing some experimenting, and might be trying different fuel pumps, etc. But for a straightforward fuel pump replacement, how much time is saved by this hack ? Z |
No time saved. I did my 97 so that I could easily change the pump while visiting friends far from home.
Originally Posted by stevenx605
(Post 980632)
An option for some wanting to have easy access to pump and all its belongings for testing and experimenting . I have a 2004 XKR convert that has been giving me some fuel pressure problems. I did not want to shell out $ 750 for the module and have to remove the tank to replace it. After reading many post about repeated new part failure and short life I choose a different approach. I plan on trying some aftermarket pumps / fuel pressure regulator if needed. First I purchased a 8 1/4" hole saw and arbor part# 106200 and 106202 from automationdirect.com for about $ 55.00. I rented a right angle heavy duty 1/2" drill from Home Depot for $ 20.00 for 4 hrs. I removed the carpet that covers the back shelf area on top of the tank to access sheet metal and made measurement's and markings for 1/4" pilot hole. Through the trunk I pulled down back wall carpet and removed top 3 bolts holding steel panel and pulled it down slightly and slid in a piece of aluminum sheet as a safety when drilling. The original arbor bit was removed and replaced with a 1/4" drill blank extending out 3/8" past hole saw teeth.Next I drilled a pilot and then cut the 8 1/4" hole in the sheet metal , all of about 55 seconds. I cleaned and deburred the sharp edge and vacuumed the area clean. You can leave the hole open ,the carpet is stiff enough not to sag or close up with original plug and use aluminum duct tape or make a complete new cover. Attached are some pics. Steve
Measurement for where to drill
Where do I drill to replace the pump in a 2004 jaguar xj8?
Thank you very much |
Originally Posted by Aj Leduc
(Post 2290357)
I too have a 2001 convertible and had to replace the pump a few years ago. Remove the back seat for a bit more room and cut through the shelf (for want of a better word) where the retracted top would sit. It goes without saying all this has to be done with the top up which makes for a cramped work area. Be sure to protect the interior of the top from any sparks.
When everything is back up and running, ensure that the removed section of metal is secured in place by some method as that area acts as a firewall. |
Wow great write up. I have a 2002 XKR and I thought I head that one of the pumps could be dead and you not really know it? So my question is is there a good way to test and see if one pump is inactive? I though there was a thread on it at one point but couldn't find it.
Thank you, Rob |
Originally Posted by crtfour
(Post 2293522)
...is is there a good way to test and see if one pump is inactive? I though there was a thread on it at one point but couldn't find it.
https://www.jaguarforums.com/forum/x...82/#post632824 |
By the time you remove the rear seat, cut a hole, make a cover for the hole, and reinstall the rear seat (don't forget the chance that you might run into unforeseen issues along the way, what are you really saving in time or work compared to removing the fuel tank? If you cut the hole for access you are replacing the fuel pump with horrible access and sight angles. I just don't see the benefit. I removed the tank and replaced the pump with the tank on the garage floor where I could see perfectly into the tank with all the access I could want. I could easily see everything I was doing so that when I put the tank back into the car I had no worries.
I guess it's a matter of preference but I prefer working this way. |
