Hello all - XK8/R or XJ8/R instrument cluster change for KPH
Finally, I have found a new partner for my final run S-Type and it is a gorgeous matching 2004 4.2L X100 - but, being a private import from UK to Australia, has an MPH i/c rather than KPH. After much thread searching, and ransacking Gus' resources at [JagRepair.com] where he has links to great pics on R&R i/c for globes, I need help and advice.
Basically, I have found no-one appears to have reported an i/c R&R. I understand why no British or US owner would need to change from MPH to KPH, and I am unsure of Euro situation where KPH reigns, but is LHD an issue? Can anyone help with these questions -
Cheers, :icon_beerchug: Ken |
I would try to see if just the (bezel?) with the markings can be swapped i.e. keep everything the same that's electrical/electronic.
Yes it's part of immo and more. For an 03+ S-Type I'm doubtful you'd succeed any other way and besides why struggle? I think the XK will be the same. If you do try to swap the tough stuff have a workable plan for an immobilised car. You can probably cajole someone into close up pics or try ebay ads to help you see if just the (plastic?) plate with the markings can be swapped. |
Originally Posted by cat_as_trophy
(Post 1397319)
Cheers, :icon_beerchug: Ken Tachoscheibe Jaguar XK8 XKR XK100 XJ XJR X308 MPH ZU KMH Tacho Dial US | eBay |
Originally Posted by JagV8
(Post 1397327)
From elsewhere on NSW Regional post, I heard from Graham and Cambo - latter offering help with any reprogramming if necessary, but pointing to much the same approach via links to Lockwoods International in UK. Many thanks to all. I will come back with update (a) when I have car and (b) when I have R&R completed. Cheers, :icon_beerchug: Ken |
Hi Ken,
I had my XK8 2005MY instrument panel changed from MPH / KPH to KPH only So the car could be imported to Australia, Our local UK dealer carried this out as the car was still covered by three warranties. This new unit gave the car a new clock display of 000000, so we lost the 12,000 miles from the original unit. But to change this unit over this will require the use of a WDS or Mongoose dealer service tool to code it to the car. And if it a used one then you would need make sure it is the correct version For you car. And to make this an expensive wast of time for us when the car arrived in Australia and we took it t o the local test station for it be checked to make sure confirmed to ADRs. We were told that the UK sppedo with Miles over K/PH would have been fine and they was no need to replace it. And they were not aware of this requirement but that is South Australia ! Regards Redpoptop |
You can just replace the faceplate on the speedo. I nearly bought a UK import, so I checked this out several months ago. Jaguar XK MPH to KMH Speedo meter clocks. Dials
Cost should be around $AUD200. Cheers, Stu |
4.2L XK8 speedo MPH > KPH
Hi Redpoptop. Hey, what a bummer . . .
But I'm not aware of any Oz state that goes anywhere close to the MOT rot I see complained of at length in these and similar UK forums. Imagine the outcry if they suddenly banned or insisted on conversions for all those classic, historic and veteran MPH cars tucked away around Australia. Shannons would spew! All those old XKs, beautiful Mk2s, our heart-snapping E-Type; not to mention all those Mustangs and Corvettes suddenly banned? WOW, you sure got some poor advice. That said, my determination to convert to KPH is now looking easier and affordable . . . Hi also Stu, and thanks for your suggestion, but . . . Alas, Lockwoods for Jaguars at least, appear to cater more for that market's need to convert KPH fitted cars to MPH - ie UK imports, not exports. For an XK needing KPH, they only offer 1 product (as per your link) and that don"t fit my XK8 which has a 1 piece triple instrument dial plate - central speedo flanked on left by tacho and on right by back-to-back temp/fuel. Annoying, as they have several such offerings among their far more prodigious MPH range - including the one I will be discarding! From elsewhere, I may have sourced a German supplier of the correct KPH dial plate - again polycarbonate, not just a cheap vinyl stick-on. Thanks to everyone for helpful advice. Cheers :icon_beerchug: Ken |
| All times are GMT -5. The time now is 12:31 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
