loss of power, engine fail safe
Second time since Friday - loss of power, ASC/DSC fault, Engine Failsafe mode and stuck at 25MPH. Pulled codes Friday - 1111, 1229, with my steady 171, 174 (waiting on vvt seals and a few others to fix those).
Saturday - I replaced battery with new AGM, did hard reset and cleared codes - drove fine Sat/Sun and this morning going into work. This afternoon - again lost power ASC/DSC/Engine failsafe and limited to 25-30mph. Pulled over, shut her down and waited a few minutes, cleared codes and she started back up drove fine long enough to get me to the house and parked in the garage - Guess it's time to get throttle body repaired/replaced |
You know you can just get the TPS these days? A cheaper potential fix than replacing the whole throttle body.
thanks dibbit - yeah I did some searching and found throttle bodies range from $390 for a rebuilt from ASI to $900 use and $2200 new - yikes!!! I pulled up a tsb from Gus's site that I am going to try first and go from there
Clean the pllug connection with contact cleaner, hose it down. This may resolve the issue for a year, does for mine
Thanks LaRue - did that last night along with replace the VVT seals (for my 171/174 issue) drove a short bit (~mile round trip) with no issues but will take her out this afternoon after work for a longer drive.
