lumpy cold running on 99 XKR
My XKR has suddenly started to run "lumpy" when starting from cold..... so far it clears after 2 or 3 miles, and then runs fine. I've given it a basic service, (new plugs, filters etc.) in case there was an issue there, but it doesn't seem to have helped. Apart from this, the car runs fine. Anyone experienced this before?:icon_confused:
Cold start relay?
Try cleaning the throttle body with throttle body cleaner. Also clean the part load breather on the cam cover.
http://www.jagrepair.com/images/TSB/...20Breather.pdf A check for fault codes would also be well advised. |
Originally Posted by mcook
(Post 807971)
Cold start relay?
Thanks for the feedback chaps: I have cleaned out the part - load breather as described in the link, we'll see how it is in the morning when it's cold. I think I will buy a code reader, but all the ones I see on Ebay state that they're only good for post - 2001 UK cars; as mine is 1999 and British registered I'm not sure if they will work correctly. Anyone any thoughts?
Cheers, John |
Originally Posted by frozennorth
(Post 808867)
Cheers, John |
Thanks a lot, that clears it up - Ebay here I come.......:icon_smile:
John |
Update: last night I cleaned out the part - load breather as described in the service sheet, and this morning it started up absolutely fine from cold and ran fine. I will clean the throttle body etc. this weekend; thanks for the help.
