lumpy cold running on 99 XKR
Old Sep 8, 2013 | 04:50 AM
frozennorth's Avatar
Default lumpy cold running on 99 XKR
My XKR has suddenly started to run "lumpy" when starting from cold..... so far it clears after 2 or 3 miles, and then runs fine. I've given it a basic service, (new plugs, filters etc.) in case there was an issue there, but it doesn't seem to have helped. Apart from this, the car runs fine. Anyone experienced this before?
Old Sep 8, 2013 | 06:25 AM
mcook's Avatar
Cold start relay?
Old Sep 8, 2013 | 07:22 AM
WhiteXKR's Avatar
Try cleaning the throttle body with throttle body cleaner. Also clean the part load breather on the cam cover.
http://www.jagrepair.com/images/TSB/...20Breather.pdf
A check for fault codes would also be well advised.
Old Sep 8, 2013 | 07:23 AM
WhiteXKR's Avatar
Originally Posted by mcook
Cold start relay?
No such animal on an XK8/R. Cold start is controlled entirely by the ECU.
Old Sep 9, 2013 | 02:32 PM
Thanks for the feedback chaps: I have cleaned out the part - load breather as described in the link, we'll see how it is in the morning when it's cold. I think I will buy a code reader, but all the ones I see on Ebay state that they're only good for post - 2001 UK cars; as mine is 1999 and British registered I'm not sure if they will work correctly. Anyone any thoughts?
Cheers,
John
Old Sep 9, 2013 | 02:47 PM
WhiteXKR's Avatar
Cheers,
John
It should work. The UK only required OBDII post 2001, but Jaguar supported it on all XK8/Rs marketed worldwide since '96.
Old Sep 9, 2013 | 03:10 PM
Thanks a lot, that clears it up - Ebay here I come.......
John
Old Sep 10, 2013 | 06:28 AM
Update: last night I cleaned out the part - load breather as described in the service sheet, and this morning it started up absolutely fine from cold and ran fine. I will clean the throttle body etc. this weekend; thanks for the help.
toronadomike
Jan 22, 2026 10:13 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
tberg
Sep 7, 2015 07:32 AM
colorancher
Sep 3, 2015 02:29 PM
