Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XK8 / XKR ( X100 ) (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/)
-   -   Newbie Needs Help Finding Parts (Warped pulley on Right Quarter Window Assembly) (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/newbie-needs-help-finding-parts-warped-pulley-right-quarter-window-assembly-271863/)
SeanXK8 Jul 19, 2023 12:11 AM
Good day All,
I'm a newbie here and have not been logged on in a long time.
I have a 1999 XK8. After being parked for a long time, a plastic pulley within the passenger side quarter window has become warped and thrown the cable, when opening the top. It looks like I need a new regulator or maybe regulator/motor assembly. The thing is, local dealership says they dont make them anymore. I can find quite a few left side quarter window assemblies on ebay. Where can I find a good used one, is there a jag parts place near me (Louisville, KY) or online, Or a way to have my existing regulator repaired, it has a warped pulley.
Sean
GGG Jul 19, 2023 02:11 AM
Sean,
I've moved your question from Off Topic to XK8/XKR forum. Members here with the same model will be able to help.
Pistnbroke Jul 21, 2023 12:51 AM
I dont have a convertable so a picture would be worth a thousand words. There are pulleys of all sizes on ebay or take the old one to a shop with a lathe and get one turned up in aluminium
SeanXK8 Jul 25, 2023 07:18 AM
Thanks Pistonbroke,
Interestingly, its a plastic pulley, and looks like its attached via rivet to the metal frame. The pulley wobbles when you spin it,and will likely continue to throw the cable. I just dont see how to remove it and I would need a specific replacement size.
Regards,
Sean
michaelh Jul 26, 2023 03:04 PM
This post from rothwell might help you:
https://www.jaguarforums.com/forum/x...8/#post1710384
SeanXK8 Jul 28, 2023 11:22 PM
Thanks Michaelh,
I actually found that similar repair kit on ebay for $25 here. I am going to work on it this weekend. As it turns out, my pulley may not be warped. it may just have a tiny bit of wobble to it, I was able to test another assembly and I see that it had a tiny bit of wobble on the top plastic pulley. Now leaving the window up for two or three years may have caused the wire cable to take shape and jump the pulley, but its crimped and twisted now so I cant be sure. I have also found a video on YouTube showing how to install the rear quarter window repair kit.
Thanks again for the great post.
Sean
© 2026 MH Sub I, LLC dba Internet Brands
