No temp reading, Battery not charging, Restricted Performance
When I start my '98 XK8 the motor runs rough, Ck Engine Light on, no reading on Temp gauge, Volt Gauge not reading. Dash reads Battery not charging, Restricted Performance. Just replaced Alt and reads 14.2 at Battery. Battery cks out with 1,000 CCA's, Fully charged.
Just curious, don't you have temp on dash?, or just not on OBD2 data?
I have same issue except temp gauge works well, just not on OBD2. (only with ELM327)
Changed voltage regulator inside alternator but without error message going away..
My Icarsoft LR2 does not connect with my XKR-yr2000...(can't see ISO9141, think car is causing this...)
rhankey
40
Oct 11, 2023 10:28 AM
