noise in fuel tank - XK8
I replaced the fuel pump on my 2001 XK8 and now i have a rattling noise coming from inside the tank. If you unplug the pump relay when ideling, the noise stops instantly. (the engine will run for a few seconds after relay is removed) There was a small 2" square plastic with holes in it under the pump screen filter. It may have been knocked out of place. Has anyone seen this problem?
Firstly, welcome.
I am not familiar with the XK8 layout, but most cars with "in tank" pumps can be noisy from little things like that getting disturbed when pump replacement takes place. Going back in is the only way. |
Welcome to the forum choctawman,
I've moved your question from General Tech Help to XK8/XKR forum. Members here with the same model will be able to offer further advice. Please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum. Graham |
